Old AT PSU Is is worth recapping?
  • blacksvk
    • Oct 2016
    • Slovakia
    Hello, I use Morex MXR-200PS PSU in my retro Pentium 1 PC. It is working fine (so far), however it is very loud - so I desided to open it up and I discovered it is full of crappy caps. Pictures: http://imgur.com/a/eSO1E
    I would like to know your opinios about this PSU, because I am not PSU expert. Do you think it is worth to recap it and replace the fan, or it is just better to look for another(better) AT PSU?
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Re: Old AT PSU Is is worth recapping?
    Hi blavksvk!
    This psu is a ok AT unit. Can output 200W no problem. I see it sometimes with different capacitors and even a fan controller board installed. Replace all capacitors on the secondary. Maybe swap the two primaries with some 470 capacity ones...
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      loud is the fan.
      but i spy crapxon.change them all.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8339
        Originally posted by kc8adu
        loud is the fan.
        x2
        • blacksvk
          • Oct 2016
          • Slovakia
          Thanks, I will change them!
          I disassembled the PSU completely and I started inspecting cap values.
          Code:
          C5: 200V 330uF 85°C TOSIN
          C6: 200V 330uF 85°C TOSIN
          C10: 35V 4.7uF 105°C CapXon KM
          C14: ??????????
          C15: 16V 2200uF 105°C CapXon KM
          C16: 16V 1000uF 105°C CapXon KM
          C17: 16V 2200uF 105°C CapXon KM
          C18: 6.3V 6800uF 105°C CapXon KM
          C19: 16V 220uF 105°C CapXon KM
          C20: 35V 4.7uF 105°C CapXon KM
          C21: 16V 4.7uF 105°C CapXon KM
          C24: 25V 10uF 105°C CapXon KM
          C25: 35V 4.7uF 105°C CapXon KM
          C26: 50V 4.7uF 105°C CapXon KM
          C29: 25V 22uF 105°C CapXon KM
          C30: 25V 10uF 105°C CapXon KM
          C31: 35V 4.7uF 105°C CapXon KM
          C42: 35V 4.7uF 105°C CapXon KM
          I cannot see the C14 values, because the C14 cap is covered in some kind of sleeve (it looks similar to heat shrink tube), see photos here: http://imgur.com/8M3pH4m , http://imgur.com/P8SIpAE . Does that sleeve serve any purpose? Do I need to keep that sleeve for replacement cap, or can I just cut that sleeve to reveal the cap inside it ?
          Also... I found out, that there ale a lot of small caps, like the C27 (the green one - see this photo: http://imgur.com/37eMlUs). Should I change these as well?
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            This may sound odd, but be careful not to replace the output capacitors with parts that are too good, that PSU is about 25 years old, and electrolytic capacitor technology has advanced quite a bit since then. The parts I'd recommend, in order of preference would be:
            1. Nichicon PS series or Rubycon YXF series;
            2. Nichicon PM series;
            3. Nichicon PJ series or Nippon Chemicon (United Chemicon) LXVseries.
            PS and PM are ROHS compliant versions of parts Nichicon produced when that PSU was made; Rubycon YXF series is of that time as well. PJ and LXV were the next newer series.
            PeteS in CA
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              Being a good stable source of 12 volts , 3 volts and 5 volts , with high Amperage rating of 6 to 10 A , definitely usable for all different electronic fields , PSUs are always worth repairing .
              • blacksvk
                • Oct 2016
                • Slovakia
                These are the caps I want to change:
                Code:
                C10: 35V 4.7uF 105°C CapXon KM => 35V 4.7uF Nichicon UPS UPS1V4R7MDD1TD
                C14: 16V 220uF 105°C CapXon KM => 16V 220uF Nichicon UPS UPS1C221MPD1TD
                C15: 16V 2200uF 105°C CapXon KM => 16V 2200uF Nichicon UPS UPS1C222MHD1TO
                C16: 16V 1000uF 105°C CapXon KM => 16V 1000uF NIchicon UPS UPS1C102MPD1TD
                C17: 16V 2200uF 105°C CapXon KM => 16V 2200uF Nichicon UPS UPS1C222MHD1TO
                C18: 6.3V 6800uF 105°C CapXon KM => 6.3V 6800uF Nichicon UPS UPS0J682MHD1TN
                C19: 16V 220uF 105°C CapXon KM => 16V 220uF Nichicon UPS UPS1C221MPD1TD
                C20: 35V 4.7uF 105°C CapXon KM => 35V 4.7uF Nichicon UPS UPS1V4R7MDD1TD
                C21: 16V 4.7uF 105°C CapXon KM => 25V 4.7uF Nichicon UPS UPS1E4R7MDD1TD
                C24: 25V 10uF 105°C CapXon KM => 25V 10uF Nichicon UPS UPS1E100MDD1TD
                C25: 35V 4.7uF 105°C CapXon KM => 35V 4.7uF Nichicon UPS UPS1V4R7MDD1TD
                C26: 50V 4.7uF 105°C CapXon KM => 50V 4.7uF Nichicon UPS UPS1H4R7MDD1TD
                C29: 25V 22uF 105°C CapXon KM => 25V 22uF Nichicon UPS UPS1E220MDD1TD
                C30: 25V 10uF 105°C CapXon KM => 25V 10uF Nichicon UPS UPS1E100MDD1TD
                C31: 35V 4.7uF 105°C CapXon KM => 35V 4.7uF Nichicon UPS UPS1V4R7MDD1TD
                C42: 35V 4.7uF 105°C CapXon KM => 35V 4.7uF Nichicon UPS UPS1V4R7MDD1TD
                Can anyone check it? Also, it is OK to change 16V 4.7uF to 25V 4.7uF?
                  • 31246
                  no problem on that voltage upgrade.
                  i'm surprised you even found that, normally a good 4.7uf cap starts at 35v or even 50v these days.
                  • Stefan Payne
                    • 1267
                    I woudn't care and just order 50V/4.7uF Parts and use that instead. Those things are more common these days so I'd rather not bother with lower voltage ones.
                    • aidanmo
                      Philips 43PUS7506/12 - Loud blown out sound
                      by aidanmo
                      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                      I thought maybe the speakers got damaged, so I replaced them - no dice.
                      • Using the internal speakers, it always happens.
                      • Using the headphone jack, it never happens.
                      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                      02-28-2025, 03:13 PM
                    • mrmazda
                      TR2 Thermaltake W0070RU XP550 NP - worth recapping?
                      by mrmazda
                      Only two search hits here, one casually mentioning lower/middle calibre many many moons ago, not terribly helpful, and the other, simply exposure to it, and neither included the RU suffix. Is this a design worth recapping to keep a 10-15 year old PC operational?
                      I replaced the obviously bad Ltec LZP 2200uF 16V and the obviously bad pair of CapXon GS 18x40 620uF 200V with Nichicon 22x50 UPT. It lights up my digital PS tester with suitable voltages, but it emits a screechy squeal that just drowns out the two 80mm fans. It probably would only very slightly annoy installed in a PC in...
                      04-11-2020, 08:13 PM
                    • Bungz
                      Morex Int'l ATX-300C, worth a recap?
                      by Bungz
                      Thought I would have a look inside this as I had a issue with a system freezing ( socket A Thunderbird system)
                      Thought it was a odd design, what do people make of it?
                      Edit - Nothing visual wrong, obviously may start with a recap but swapping the PSU solved the freezing issue.
                      I like older socket A systems so these older PSU that are weighted towards the 5V rail always catch my eye....
                      08-18-2021, 01:35 AM
                    • proxneo
                      Recapping Sony ICF-SW55 - verifying cap values
                      by proxneo
                      Dear reader
                      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                      At the moment, I have selected replacements based on the following list of values:
                      3 x 470uF 10VDC
                      3 x 4.7uF 35VDC
                      4 x 47uF 50VDC
                      8 x 22uF 6.3 VDC
                      1 x 220uF 6.3VDC
                      5 x 100uF 6.3VDC
                      Which...
                      06-21-2023, 12:38 AM
                    • mon2
                      Crate guitar amp with extremely loud static on power on (no input)
                      by mon2
                      Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                      07-18-2025, 06:40 AM
