CyberPower 1350AVR - Repair
  • ehsjr
    • Jul 2022
    Re: CyberPower 1350AVR - Repair
    Originally posted by RETUSNET
    I just wanted to add that I had the same problem with my CyberPower 1350AVR and replacing C1 fixed it.
    What started as looking for a schematic or suggestion as to how to test the charging circuit ended up finding the repair. Thank you Plastcirelic.
    Yes! My 1350AVR same problem, same repair, C1 22uf 50V. I actually ordered C1, C3 and C6 as well as the Viper chip, but, while waiting for them to arrive, checked ESR on the caps. C1 was bad, C3 & C6 good. Pulled C1 - it measured 460 nF instead of 22 uF. Substituted a 22 uF 160V (no 22uF 50V on hand).
    Had to solder on wires (and heat shrink) and lay the cap on the board elsewhere as its diameter is bigger than a 50v same value cap. Works fine now. (If I had the other caps would have replaced them, too.) With thanks to those who posted the solution here! Ed
    • braincell38
      • Jul 2016
      If your battery isn't charging, usually you can just replace the small cap C1 22uF 50V next to the VIPER22 chip. The VIPER chip has thermal shutdown protection so shouldn't burn itself up. I tested C2 and C3 on my mine and they were fine.
      You may notice a very high pitch sound from your UPS if C1 is bad.
      • gintanto
        • Aug 2024
        When I powered mine up after being unplugged for several years (with brand new batteries), I immediately heard a hiss and then the magic smoke came out. The magic smoke came from my Viper22a chip, which completely obliterated the markings, and I didn't even know what it was til I got here :-) Both of my 200V caps are swollen. All the other caps look ok. In short, I think there are probably multiple failure modes for this part, especially depending which caps died.
        I just placed my Digi-Key order, and will update when I get the parts installed.
        • SharkSandwich
          • Nov 2025
          Thanks to this thread here at badcaps.net, there's been another simple $1 repair = I just replaced only C1 (22µF 50V) and my CP1350AVRLCD is fully restored to health! I did choose to "elevate" C1 up from the board = rather than solder it "down" on the board I put about ½" of small heat-shrink on the capacitor legs, then soldered C1. I'm hoping an "air gap" above and away from the VIPER22 chip might make C1 last longer. THANK YOU!
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • ipatch
            troubleshooting microsoft surface pro 4 no power no led charge light
            by ipatch
            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
            10-05-2023, 11:59 AM
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
          • ruletero
            Acer a515-43 low battery charge voltage
            by ruletero
            Hi
            Acer A515-43
            LA-H801P
            Fail: Does not charge battery, has low voltaje on connector.
            Laptop didn't want to turn on, only charge led blinked.
            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
            10-24-2022, 02:31 PM
