Fractal 1000w shut down if gaming
  • drag
    • May 2016
    • 18
    • finland
    Hello, Fractal power supply works well but if i start gaming computer shut down?
    I opened power supply and no bad condensator found.
    Where to start finding broken parts?
    Sorry for my bad english.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Fractal 1000w shut down if gaming
    You didn't specify the model.
    Looking at some pics it seems the caps sit in an area with very poor airflow right up against the heatsinks. (If I found the right model).
    So it's a possibility if they have been cooked, how old is the PSU / how much have you used it?
    Pics?
      • 31070
      maybe it's not the psu.
      check how hot the cpu is running.
      • drag
        • May 2016
        • 18
        • finland
        It's Fractal design newton R2 1000w 80+
        Model: FD-PSU-NEWT2-1000
        Power supply are little broken because any other power supply works well on same computer.
        • drag
          • May 2016
          • 18
          • finland
          It is very much similar to this picture.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No way is that 1000w rated looks quite poorly built IMO.
            • Viperel
              • May 2016
              • 34
              • Romania
              Would be nice if you could provide some personal photos of the PSU, to see if there are any issues with it.
              • drag
                • May 2016
                • 18
                • finland
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Looks like United Chemicon caps so probably not it then.
                  Did you try the computer on another powersupply, maybe try borrowing one from a friend if you don't have a spare?
                  As stj said it might be a problem with something else...
                  • drag
                    • May 2016
                    • 18
                    • finland
                    I forgot to say that former owner said that power supply shut down randomly.
                    What are usually broken if power supply shut down randomly?
                    • drag
                      • May 2016
                      • 18
                      • finland
                      I found this:
                      https://www.mikesarcade.com/cgi-bin/...e=psrepair.txt
                      "Diode failure is another common problem. There are quite a few diodes
                      in a switching supply and failure of any one of them will cause the
                      supply to blow the fuse or shut down. The most common diode failures are
                      shorted +12 volt or -5 volt output rectifiers. Failure of these diodes
                      will not blow the fuse. The supply simply detects the short and shuts
                      itself down."
                        • 31070
                        i cant see any pictures.
                        fotofuckit or imgur again i suppose.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          stj: I uploaded the photos.
                          drag: please attach the photos here in the forum instead next time.
                          For you quoted text it is not your failure condition, in that case the PSU would not turn on.
                          It could be a bad solder joint or simply dry capacitors.
                          But you need equipment to be able to test them (an ESR meter)
                          If you don't have one you could just change them all and hope for the best but I don't like your chances...
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            Those indeed look like ChemiCons, but i wonder what series?
                            KZG's have been known to crap out (seen a few of those myself, on mobos), in some cases...
                            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                            • Stefan Payne
                              • 1267
                              You should NEVER EVER excluded something if you haven't tested it, if it is a probable cause for the failure.
                              The caps are a possible cause, so they should be measured to be sure...
                              Though I'd first try to figure out if it is the PSU and not the PC...
                              And if the fan is spinning
                              Probably KZE series...
                              And KY for Standby.
                              Well, there are many people in forums with failed Seasonic X/P series PSUs with failures that sounds like the caps are defective...
                                ASUS TUF Gaming FX506HF-HN028-GAMING Notebook F15 Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX506HF-HN028-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HF-HN028-GAMING boardview and FX506HF-HN028-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-07-2024, 06:38 AM
                                ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook A15 Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FA506IU-HN153T-Gaming boardview and FA506IU-HN153T-Gaming schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 11:20 PM
                                ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 09:01 AM
                                ASUS TUF Gaming FX505GM-AL323-GAMING Notebook Specification for Upgrade or Repair
                                This specification for the ASUS TUF Gaming FX505GM-AL323-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505GM-AL323-GAMING boardview and FX505GM-AL323-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                MSI Gaming GP73 8RE-062UK Leopard + Gaming Voucher Notebook GP Specification for Upgrade or Repair
                                This specification for the MSI Gaming GP73 8RE-062UK Leopard + Gaming Voucher Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP73 8RE-062UK Leopard + Gaming Voucher boardview and GP73 8RE-062UK Leopard + Gaming Voucher schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-06-2024, 08:41 AM
