m-tec gutless wonder
Re: m-tec gutless wonder
I actually had one of these under the generic brand of "PRO POWER". It had CapXon capacitors in it, and I did use it to power and AMD K6-2 450MHz computer a long time ago while I was waiting for a better power supply to come.
It failed later in that AMD K6-2 450MHz computer with a loud pop, the fan outlet was also lit up for a second. It turns out to be a blown fuse. I didn't bother repairing it, since it was so crappy. The computer luckily survived, and the better power supply (an AOpen 250W PSU) came soon after. I still have this power supply in its dead state in my junk bin.
I don't know who manufactured this power supply, since it had no certifications (UL, CSA, etc.) on the label. Probably a drunk 20 year-old designed it, because it is worse than your typical DEER/L&C/Allied power supply.
A small computer store I know of sells a Pro Power 450W power supply with the 24-pin ATX motherboard connector along with P4 and SATA support, but I wouldn't buy it as I have not had a good experience with Pro Power (whatever they are). Probably its just this crap power supply with the 24-pin ATX motherboard connector, P4 +12V connector, SATA connector, and a 450W label!Last edited by Newbie2; 09-02-2008, 10:40 AM.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bitComment
came from a system another shop trashed.
had a asus p4c800 deluxe board in it.
and they wondered why the system wont post!
note lack of p4 +12 .
board is fine as is the 2 gigs of ram and p4 3.2 proc.
i love getting castoffs from dumbasses!Comment
That would be a great system as a backup computer or to give to a friend or relative to use.Originally posted by kc8aducame from a system another shop trashed.
Even if that PSU had a P4 +12V connector, probably that PSU wouldn't last long and kill the whole computer when it fails.My gaming PC:
Looks like it has all the colors in the rainbow. Colors are something noobs die for..lolQ6700 @ 3.6 GHz
Zippy GSM-6600P
Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
Abit IP35Pro
ATi HD4870Comment
Assuming...7 Photos -
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
			by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
			by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
 - Loading...
