This may not be the right place this but here it go --->
Awhile back a few month ago the itera light and the door ajar buzzer would not shut OFF
unless you remove the fuse for the itera light
There is controller that controls the following ---->
Which had bad 100uf@35 volt cap on the control boatrd
The windshield wiper speed and timing speed
The speed odotomer and the mileage meter
The itera light
More about this later----->
Then the dash light went out the dimmer controller failed the MOSFET or transiter broke lose from the board and on top that there two caps also on the board 10uf@50 volt ESR value of (3.2) the second one is 47uf@50 volts ESR value (3.7)
When it did work the dimming was not very smooth controlling the light level
Now back to other --->
The mileage meter did not work because of a bad small stepper motor the gear sheared off
got one out of the junk yard and now that working again
Taking out this dash is a real pain in the ***
So now I can see the dash in the dark and the mileage meter works and the buzzer dose not keep sounding any more
The itera light
