( back photo - http://s232.photobucket.com/albums/e...067busted2.jpg )
So, recently I turned one of my folding machines - a "webserver" one, using Abit KD7-G mobo and powered by Enermax 431W PSU ( http://www.pcstats.com/articleview.cfm?articleID=409 ) and mid loud explosion happen. Machine did not power on anymore.
The PSU is recapped with quality caps, but I'm affraid that with the Panny TS-ED caps in the input, their ripple is maybe too high and ESR too low, so maybe that is what caused the mosfet pictures above to end how it end. After cleaning I find out that also the 2M ohm resistor to the base of this mosfet is damaged (part of it's leg to the mosfet is gone) and 10A 250V fuse is busted badly - almost like the wire exploded and wallpaper itself on the glass of the fuse
Nevermind. It looks as Fairchild component, very similar (likely) to this Toshiba mosfet: http://www.alldatasheet.com/datashee...A/2SD3067.html
Basicaly it is 600V mosfet, 2A current (1mS pulse 5A, 100uS pulse 8A) with RDS(ON) 4.5 ohm and plastic core. Can't find anything on http://www.fairchildsemi.com
So, anyone got idea about available higher grade (mainly lower RDS(ON) and higher current, at least 4A ... ) replacement, guys?
) so I don't know how they are generally designed, I have experience with flyback and step-down converter, so I can't give you more details.
