Bulb trick replacing fuse ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Is it safe if I change the fuse temporarily with bulb to see a short circuit in a high side of power supply ?
    Will the bulb blow ? or it's just glowing replacing a fuse ?
    Will I burn something else and make it worse ? Or the energy ( high current) has been passed to the bulb and will not damage anything else
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Bulb trick replacing fuse ?
    The bulb will limit the current. It will only allow the power (watts) at which it is rated through, thus It will prevent fuse (or other components) from blowing.
    Follow the white rabbit.
    • bianchi77
      • Jun 2016
      • 1121
      for example the device I want to test is 24VA....it's ok if I use a 60W bulb ?
      so the bulb power must be higher than the device I want to test ?
      if there's short, the bulb will be on brightly, if not....it's not on or dimming ...?
        • 31011
        dont know about the whattage, but the rest is correct.
        i find that if the wattage is to low for the device to run, it's still o.k. for testing if something is shorted.
        • bianchi77
          • Jun 2016
          • 1121
          the bulb is not blowing if there is short, isn't it ?
            • 31011
            if there is a short the bulb will go bright.
            just as long as the voltage is not higher than the bulb rating.
            • bianchi77
              • Jun 2016
              • 1121
              You mean...the input voltage?240v and it will protect the circuit into further faulty?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                24VA...Is that correct??...If you are working with 220V then you will be using 0.11 Amps??
                • jshhh
                  Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                  by jshhh
                  Hi guys,
                  I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                  How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                  Anybody know how to remove this type of fuse?
                  (The fuse is toward the bottom of the image labeled F2)...
                  06-17-2025, 01:35 AM
                • corrize
                  Replacing resistor fuse in Sony DV charger
                  by corrize
                  Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                  So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                  It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                  06-30-2025, 06:59 PM
                • JimBanville
                  Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                  by JimBanville
                  I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                  Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                  01-24-2023, 07:49 AM
                • corrize
                  A funny fuse story – Lumix LX100 II
                  by corrize
                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                  10-19-2023, 09:58 AM
                • repair-it
                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                  by repair-it
                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                  10-11-2023, 07:18 PM
