Mastervolt Chargemaster 12/35-3 Charger - Failed repair - erratic output
  • sententia
    • Oct 2013
    • 269
    • Greece
    This charger had the bridge rectifier and mosfet (in red rectangle) shorted, so i replaced those and the main input filter caps as they were about 20% down of their capacitance.
    I thought the charger was working good but after some time of being switched on the charger output high voltages around 20V and gets unstable. It detects the high voltage output and restarts. The heatsink that has the bridge rectifier and mosfet gets hot without any load. Although i haven't managed to find which of the parts on the heatsink is produced the high temp. Also the 2x 51K 2w resistors get about 55c degrees and all the area around that gets quite hot. The voltage on the main filter caps is steady around 180V.
    Now i removed some parts to check them and put them back in the charger has the problem almost straight away upon power on.
    Any ideas of how to troubleshoot this problem are very appreciated!
    Thank you!
    Please ask for any more info you may need!
    P.S. Mosfet is a SPP20N60C3
  • CapLeaker
    Leaking Member
    • 8196
    Re: Mastervolt Chargemaster 12/35-3 Charger - Failed repair - erratic output
    I'd be looking at the feedback circuit, cold solders on the secondary, any glue that got conductive, corrosion, etc...
    Try heating things up with a hair dryer and see if you can make it act up faster, while monitoring the output with an oscilloscope.
    On your last picture the 2 smd caps don't look that good. Replace those for starters. Clean / replace the opto in front of them too. Clean the whole area. You may have to remove. Some components.
    • sententia
      • Oct 2013
      • 269
      • Greece
      I have a difficulty identifying the feedback circuit.
      On the first picture i have marked the track of PIN 2 which is the feeback of the 2845B ic on the botton side. It does not connect to the opto mentioned i think. The vertical board now has a TL494 and there is a TL431C as well there. I cannot understand which is for standby circuit and for main charger.
      This power supply has a standby circuit which operates until power button is pressed and the relay closes.
      Now those capacitors look like this because i have remove the 220uf one to test it and putting it back on looks like that ..... The 220uf tested good, as the red one (MKP i think) 22n 630V next to it. I did not remove/test the 100uf one but on board i get much more that 100uf.... These caps are low ESR 25V 5000h. The small one is 2000h.
      If by clean you mean the whitish foggy thing on board its the protective material that is on the entire board. It is extremely difficult to remove (and test components) and the white finish appears after isopropyl alcohol is applied to make it a bit softer.
      Thank you!
      • CapLeaker
        Leaking Member
        • 8196
        start to heat things up in there and see if you can "make" it act up.
        • sententia
          • Oct 2013
          • 269
          • Greece
          After removing some parts for testing, including those caps, and putting them back in the charger goes straight away to 20V.
          So far i have tested the parts marked in the photo and quite a few resistors at the bottom of the pcb. Only the Y capacitor seems a bit off only by my "transistor tester" if i measure it with the DMM capacitance it measures ok, but i doubt that it is causing the problem. The are another 2x TL431 marked in the photo. I still haven't distinguished which parts are from which circuit.
          Thanks capleeker for guidance!
          • CapLeaker
            Leaking Member
            • 8196
            When you test the output, do you have a load on it? Oh, I forgot to mention something. Sometimes a resistor changes it's value (usually it either goes higher in the ohms reading or open). Make sure the resistors are within spec.
            In front of that little board (bottom left) there are 2 more optos and some caps. Did you check these?
            When you monitor the output, is it stable for a while, then goes erratic until it shuts off? Then cool down for a while until it will start again and same thing again?
            • sententia
              • Oct 2013
              • 269
              • Greece
              ooops i didn't post my previous message ......
              I do use my variable current dummy load to test the charger, however only on 1 out of 3 channels. The charger can be used as a power supply on "FLOAT" mode where output voltage is 13.25V.
              In front of the vertical board i have tested the two caps and both optos. All tested good.
              Now about the resistors i measured. Some have normal code "51R0" etc and some have coding of "01B". I did check measurements compared to marking only for the first ones as i see the "01B" marking ones have irrelevant resistance. "69B" for example is 5.11K.
              The charger only switches of for 2-3 seconds before going back on and giving 20V.
              Anyway at the moment i did put back all the parts tested, except one 100uf capacitor next to the opto which i destroyed it upon removing and replaced it with a FR one.
              Strangely now the charger is on for almost an hour and still haven't presented the problem.... hhhhmmmmmm
              EDIT: Is it normal that the primary heatsink is getting hot 33c and bridge rectifier and diode rectifiers at 42c without any load??
              The charger only draws 15w from 220V at this state though and no current on the output of course....
              • sententia
                • Oct 2013
                • 269
                • Greece
                Ok it went to 21V....
                The transformer is quite hot at 58c, the fet next to it is at 50c, 1 out of 2 TL431 is significantly hotter than the other. I marked the in photo.... if that helps at all!
                • CapLeaker
                  Leaking Member
                  • 8196
                  Not sure if the heat is normal or not. I think the charger must have something like a cooling fan that takes the heat off the heatsinks. Maybe you have disconnected it. After all it does 35 amps on 3 channels and total power consumption is 575w on 230V. So 15W idle doesn't sound too bad. If the fan runs all the time the heatsinks would be cool like cucumber. Since you have that thing cracked open anyway, I would change all small caps that see heat, like near a heatsink.
                  Those resistors with the funny marking like 01B (1kohm, so check them again out of circuit) is after the "EIA" marking code. Here is a list:
                  http://www.talkingelectronics.com/pr...-Markings.html
                  • sententia
                    • Oct 2013
                    • 269
                    • Greece
                    The fan does not run at all times. It kicks in when i increase the load to 1A or 1.5A and as soon as i decrease the load it switches off. The charger does have a sensor on the main transformer and on the secondary heatsink.
                    I have removed all 3 TL431 and did a simple test to check if they produce 2.5V, so they all look OK. However on board one of them gave only 1.9V reference but this could be, i think, because of resistor network or the fact that i used 5V supply to test it...
                    • sententia
                      • Oct 2013
                      • 269
                      • Greece
                      So far i replaced all TL431, replaced some caps just in case and tested many many resistors. The only thing that is a bit off is a ceramic 471K 1KV cap (marked in circle in photo) that measures 440pf. I don't know if that can cause the problem.
                      Also i remembered that the charger operates with just the batteries connected so i started to probe the optos and some other staff on board with safe voltage.
                      Almost everything i probe give a 50hz signal.
                      Moreover the charger has 3 different charging states bulk, absorption and float (according to IUoUo algorithm) with different output voltages and current. Does that make the mosfet i replaced controlled by the microprocessor to regulate the output voltages?? Are the feedback circuits monitored by micro or by pwm ics?
                      This charger and this awkward problem is a nightmare!
                      • CapLeaker
                        Leaking Member
                        • 8196
                        Did you try heating the board up first and see if it goes to over volt protection? I wonder if you could isolate the problem by using one of the other charge outputs and see if it acts up on one or all three outputs. Compare them. To me what it sounds like is that the problem is either a cold solder joint on one of the power rails on the secondary or something is wrong with the feedback circuit.
                        Intermittent chasing is hard and at time you have to be creative.
                        The mosfet you replaced has a driver PWM on the gate, on that driver is the feedback circuit, that comes from the secondary back to the primary. Since there is no schematic you would have to find the PWM, pull the data sheet, find the pin for the feedback and trace it. Or go from the secondary, back to the opto to the primary. Key is to measure the charge output constantly (I used a oscilloscope), then I used my hot air station and heated up individual parts until I found an invisible bad solder joint. Each time I heated or cooled the inductor, I could see changes on the output voltage. It was a dual voltage power supply on a Norstar nt5b01 phone system. If you want you can read the thread.
                        • sententia
                          • Oct 2013
                          • 269
                          • Greece
                          I read your thread, and just got what you are saying about heating up the board. No i haven't tried that yet, but i will as soon as i put some parts back after some more troubleshooting and shopping for a couple of ceramic caps.
                          All 3 channels act exactly with voltage output. Anyway in forced float mode they should all give 13.25V but it happens in all modes....
                          Now what i didn't know is that the mosfet i replaced is driven by a 2PCS01 PFC controller circuit through those 2x big transistors, on the vertical board (check photo). The opto there connects all the way to the opposite corner of the pcb where the other micro is and the communications board. When you say "monitor the charge output" you mean from ic to opto or the gate drive pin?
                          Also one strange thing i noticed is that i powered up the charger and forgot to place that opto that i had removed for testing. The charger acted exactly the same giving 20V output upon power on.
                          Thanks capleaker for your help and suggestions!!
                          • CapLeaker
                            Leaking Member
                            • 8196
                            too bad that there isn't a schematic or a block diagram for this thing. With charge output, I meant one of the three 12v output channels. Put it in constant float mode, put a 12 v light bulb on the 12v output, put your oscilloscope on that channel and make it scan real slow, so you can see like 20 or 30 seconds. Start heating and cooling (can of air upside down) things. Once you found the offending part, you will see changes on the oscilloscope.
                            • sententia
                              • Oct 2013
                              • 269
                              • Greece
                              I have put everything back together, i had to replace 4 electrolytics that i destroyed while removing them and 1 ceramic 102k 1kv which i replaced with a blue one 102 3kv (i think this one is 20% tolerance compared to 10% of the original ceramic). I redid some soldering connections on board and put it on test with the dummy load at 0.8A.
                              It has been operating for 10 hours without any problem and steady output.
                              I used my hot air station at 200c on the bottom side to try and make it act but no difference....
                              Actually some soldering connections had small cracks (on microscope) and i lean forward that it was indeed a bad soldering or something like that. I will redo the chokes as well to be on the safe side.... I will get some 20w lamps to put some more load on it....
                              • CapLeaker
                                Leaking Member
                                • 8196
                                Hopefully it works now. You have to put the heat on the component side of the PSU. To me your board looks like corrosion. Never the less an intermittent is hard to troubleshoot.
                                Maybe charge some batteries up and see what happens.
                                • sententia
                                  • Oct 2013
                                  • 269
                                  • Greece
                                  I have tested the charger with 3x 20w lamps for 10 hours. Now i have it running on batteries for 2 days and no problems...
                                  I come to conclusion that it was a bad soldering problem....
                                  It is also possible that i stressed the vertical board while repairing and flipping over the pcb. I also did the coil and transformer soldering again using lots of flux and new solder.....
                                  Thank you capleaker for input, guidance and help! I really appreciate it!
                                  P.S. I got a heartbeat for a day or so... the charger gave "internal failure" after i put everything inside the enclosure. I turned out that i had the fan disconnected!
                                  • CapLeaker
                                    Leaking Member
                                    • 8196
                                    Glad to hear that you got her finally working. A1! I figured that the charger would do a failure of some sort if the fan is disconnected. Been there, done that too... Don't feel bad...
                                    • Randolfo
                                      • Dec 2016
                                      • Brasil
                                      Mr. CapLeaker, If you can help me on a Mastervolt Chargemaster 12 / 35-3, I thank you. The fault is: this stop. In capacitors of 680u / 250V has a voltage of 187Vdc. In the zener ZDB8 has 6.9Vdc and in the pins of the 2845 CI only has 6.9Vdc in the pin 7, I understood that the firing in the 1 does not occur. You can guide me, grateful.
                                      • CapLeaker
                                        Leaking Member
                                        • 8196
                                        Check if the UC2845 PWM gets proper VCC voltage so it isn't in under voltage lock out and check the startup cap. I haven't pulled the spec sheet, but if the 6.9V are the VCC for the PWM, then it is too low for it to start.
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                        • nath1977
                                          Wier WA505 SMPSU output failed
                                          by nath1977
                                          Im about to repair a failed Wier WA505 power supply which hasn't been used for many years. It was working for 30 mins or so, then started to smell bad so switched it off quick.
                                          On closer inspection a 1500uF cap across the 5v output has swollen. Adjacent to this is an overheated (open circuit) resistor.
                                          Ive removed the electrolytic cap and resistor - the cap replacement is straightforward and will replace the adjacent ones at the same time. The resistor looks like it sits across the output. Any ideas what value this is likely to be? Was thinking 100R 1/2watt would be suitable....
                                          10-01-2023, 06:05 AM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
