12vt Webasto HL32 diesel heater and thermostat wiring
  • DavyMac
    • Apr 2014
    • 35
    • Scotland
    Anyone good with electrics? Currently sorting out my Webasto HL32 diesel heater for my camper van (old but still works and throws out some heat) the manual is here and wiring dio's on Pg38 onwards http://butlertechnik.com/download/9G..._optimised.pdf
    http://www.heatingcontrolsonline.co....hermostat.html
    Looking to fit this timer to it so wondering if anyone can give me some pointers on how to wire it in
    as having some trouble understanding the diagrams on the webasto manual. Looking to wire in a rheostat to control the motor speed.
    If I can fit this then saved a packet as the webasto stuff is an arm and a leg for what you get.
  • redwire
    • Dec 2010
    • 3910
    Re: 12vt Webasto HL32 diesel heater and thermostat wiring
    I looked and the electric motor drives both the combustion air and hot air fans. It seems to be two speeds, part load for start-up/cool down, and full speed.
    If you slow the fan down, it upsets the air/fuel mixture and it might turn too slow and stall during part load sequence. Or the heat-exchanger would roast with full flame and low airflow. I think it would be a safety issue, this thing is designed for certain fan air flow for combustion.
    If you wire in rheostat (at X5 between pin 2 and the motor, but after the resistor R2, so R2 still connects right to the motor) you can change the full-speed but not part load speed. You'd need to lean out the mixture.
      • Jul 2011
      • 6040
      I do not know if this will work work the way you want it to
      Here is why
      The controller dose a few thing it not just a timer and it not just a thermostat it dose alot more it controls the heating of the fuel that just to name a few things and I did not read the hole manual but from looks I do not think that you can not with out changing a lot controls you would have use a microcontroller to maybe do it that might be a big maybe
      Now if was undertaking this I might find a way do a work around but I would have to have my hands on the unit and still might be a big maybe
      • DavyMac
        • Apr 2014
        • 35
        • Scotland
        Cheers for the replys so far, Looking at youtube someone has made a remote for it but hasn't been active for some time
        https://www.youtube.com/watch?v=wxQ42s37vTw
        The manual does show a mechanical thermostat and a digital timer as optional extras on page 8
        The on switch/rheostat I'm planning to use is this one here on page 17 if you can advise on wiring this in?
        http://www.melloronline.co.uk/produc...3539598343.pdf
        My thinking was along the lines of wiring the thermostat into the main 12v feed prior to the rheostat and leave the rheostat on the on position so that the current would be interrupted until the temp dropped
        • madan1
          Diesel heater emergency power supply / poor man's UPS
          by madan1
          Hello everyone.
          Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
          12-18-2022, 08:05 PM
        • SolomonMan
          Nest Thermostat Discussion...
          by SolomonMan
          All,
          I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
          The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
          Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
          At my boy's place he has a York Stellar...
          12-11-2022, 10:54 PM
          Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
          My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
          06-22-2025, 10:23 AM
        • edugimeno
          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
          by edugimeno
          Hi!!
          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
          At a certain point, moving stuff around, I put all wires back in place and...
          03-24-2024, 02:31 PM
          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
          12-16-2023, 08:39 PM
