Tripp-light Smart online UPS SU1500RTXL2UA...No Power Issue!
  • danyboy
    • Mar 2016
    • 5
    • usa
    I was just looking to get some advice on a couple of Tripp-light smart online Battery back up UPS's that I have with a "No Power on Issue" When plugged in I get no lights, no fans....The few things I did was #1. bypass the reset button and still no go...#2. I pulled the board and check for any burn marks, bulged caps, etc. But everything looks brand new? #3. the final thing I did was charge the 4 batteries in both the units ( 4-12v 7.5amp battery's.) and it looks like none of them will hold a decent charge! Looks like units have been sitting for awhile... one of the batteries had a date of 12/20/14
    I have had big units similar to these with bad batteries and they would still power on, fans run etc but would give a code/light on the face for faulty/dead Battery's....
    Does anyone know if these particular tripp-light units need fresh batteries to power up?? I would not think so, but I cant really seem to find any other issues with the 2 units? I did not find any hot/burn marks on boards, fuses good, and caps test ok?
    Any Ideas? advice? Any help much appreciated!!
    Thanks!!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8339
    Re: Tripp-light Smart online UPS SU1500RTXL2UA...No Power Issue!
    I think that this is a "online" UPS. Those should go even without a battery installed, as it still should condition power, because the inverter is always on. I don't have that particular brand, but I have some same vintage. I can take the batteries right out and it will turn on. Of course it does complain about the battery etc.
    Take the batteries out, plug the unit in and hold the on button in for like 5 seconds until it starts.
    You also can try to put a power supply on the UPS's battery terminals and turn the unit on without being plugged in to the mains.
      Can you still communicate the UPS the with PC?
      It has Two years warranty.
      https://www.tripplite.com/support/SU1500RTXL2UA
      • danyboy
        • Mar 2016
        • 5
        • usa
        Thanks Guys, I will try all the above and let you know!
        I did not purchase these units new so the warranty route will probably not be an option...I picked these up in auction for like 25.00 bucks each..So no big loss If I don't get them working..they do have plenty of high end parts to scavenge If I don't figure out whats wrong with them..I will keep you posted on the results of tests... Thanks for reply's!!
        • danyboy
          • Mar 2016
          • 5
          • usa
          I just wanted to follow up with this post just encase someone else had the same trip model or issue with it!!
          I ordered 4 new battery's for this unit and once I installed them "presto" she fired right up!! So, This model of tripp-light DOES in fact NEED good battery's to power up!!! I got both units working great with new battery's...Just FYI..
          Thanks...
            Thanks for the follow-up, I would think the ERROR LIGHTS they put on the front of the unit is supposed to help the customer to know if the batteries are bad or not but I guess not.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8339
              I am surprised that this online UPS doesn't run without the batteries. Mine do... different brand though... go figure...
              • dbuergi
                DIY: Modified smart charger for all types of batteries
                by dbuergi
                sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                My first work was to bring my Samsung watch battery back to life with was not recognized...
                07-18-2025, 03:17 AM
              • carrzkiss
                Cyberpower cps1500avr not charging batteries
                by carrzkiss
                Hello, all.
                Cyberpower Battery Backup Unit.
                I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                Checking the voltage, it was down to 22v.
                I quickly removed everything...
                06-15-2024, 02:10 PM
                HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                09-12-2024, 02:30 PM
                HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
                HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
