FSP300-60 rev.2
  • fulfunc
    • Mar 2016
    • 6
    FSP300-60 rev.2
    Help people !!
    I have salvaged an fsp300-60 that I am currently cleaning up and refubishing to work as a simple desktop power supply for +12v, +5v, and +3.3v
    generally going ok BUT troubles with +12v and identifying what the 3 trimmers are for: VR1 is right beside the PS-OK wire, VR2 is righ beside +3.3v wires, and VR3 is at rear of board near fsp3528 chip.
    I haven't been able to find any schematics for this unit, just spec sheets.
    +5v is giving me +5.24 --- great
    +12v is giving me +11.2v ---jumps to 11.6 if I disconnect the fan
    any ideas on what is happening and what those trim pot are specific for??
    • 31046
    Re: FSP300-60 rev.2
    did you recap it?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Re: FSP300-60 rev.2
      How much load do you have?
      Older group regulated PSU designs require a minimum load per rail...
      • everell
        • Jan 2009
        • 1514
        Re: FSP300-60 rev.2
        What mother board are you using? Did you measure the output voltages with the power supply attached to the mother board or just running not attached to anything?
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • fulfunc
          • Mar 2016
          • 6
          Re: FSP300-60 rev.2
          I am running it as a desktop standalone with a 52 ohm 5 watt load across the +5v .
          Measurments all made with Fluke DVM at front terminals ---
          I have removed the output cables and replaced them with simple terminals and a power switch mounted where the output cables used to be.
          I also put an LED across the +5v so that I can see when it is active.
          Changed fan to Fractal R2 quiet fan -- controlled by thermal controller that FPS called their Noise reducer.
          This was a unit that I salvaged from someone's scrap to make a standalone power source for general electronics activities, including teaching my grandchildren ....
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: FSP300-60 rev.2
            You have to have a higher load on +12v for it to be stable.
            • fulfunc
              • Mar 2016
              • 6
              Re: FSP300-60 rev.2
              Hi guys !!
              The answers to your questions --
              main chip is an FSP3528 310 1971C
              all measurements are made at the front output terminals using my Fluke 87 and confirmed with my Fluke 37 -- both are calibration traceable -- I needed them for my work servicing instrumentation and process control equipment.
              VR1 has markings "102" and is located beside the PG wire and near the PS-ON wire
              VR2 has markings "202" and is located beside the +3.3v output wires, and is connected to the +3.3v sense (brown wire)
              VR3 has markings "501" and is at the rear close to the AC input
              I am assuming that the +3.3 sense is regulating the +3.3v and +5v lines.
              I do not know what the VR1 is for unless it has something to do with the power good level and timing.
              I am guessing that VR3 likely has something to do with the overall gains to regulate the +12v, +5v, and +3.3v, but I could be totally wrong.
              This is one of those situations were a schematic and/or service manual for this old beast would help tremendously.
              I have sent a request to Sparkle Power, noting that this is an old obsolete model, out of production, but useful for us legacy boys.
              It also has the termination points for an OCP panel, which I know nothing about, but could prove useful to someone.
              Mike
              • fulfunc
                • Mar 2016
                • 6
                Re: FSP300-60 rev.2
                Per Hanson ;; outputs are stable as a rock -- the cooling fan also draws on same +12v power -- if I remove fan and load resistor then the +12v drops it moves.
                I have left unit running and watched stability for over 12 hours -- perfect
                Specs call for all outputs to be stable at no load as well as with load ...
                They also suggest that with +/- 5% as quoted regulation, the current readings would be within spec JUST BARELY.
                I look at the unit as having had the benefit of a "long burn-in", so it should be stable and settled wherever it is -- now it is ready for tweaking to desired output levels
                Mike
                • RebeuKooldu69
                  GL752VW Rev2.1 schematic & boardview....
                  by RebeuKooldu69
                  Hello Guys,
                  i think it is hard to find the GL752VW Rev2.1 schematic and boardview ! I have the same problème like "heso64", i don't know if he had resolved the issue at this time.
                  My Laptop was in standby and when I wanted to turn it back "on" by pressing a key it was "off". By pressing the "Power" button it did not turn back on and when I removed the plug from the power connector then reconnected -> it turns on with only 3 lights (Power, CAPS LOCK and Airplane mode) and no screen display or BIOS.
                  I searched and I can't find...
                  07-19-2024, 11:41 AM
                • nd03
                  Asus Q326FA Rev2.0 (UX362F/FA) BIOS
                  by nd03
                  Please I would need the Q326FA REV2.0 Bios cleared. Somehow my laptop I fixed got corrupted and it will not power on display (including backlight).
                  This is my current BIOS. It was ok display was coming up while I was debugging something and suddenly it stopped. If it helps the battery indicator blink 4 whites. CPU fan spins. I have VCC Core rails. VCC GT (graphics) not coming up but no short I think Bios is not requesting graphics.
                  Laptop Model: UX362F
                  Motherboard Q326FA Rev2.0
                  There was an issue with intermittent display flicker so I was working on...
                  02-13-2024, 01:58 PM
                • mo998
                  Lenovo Ideapad 5 14ALC05 LA-J701P REV2.0
                  by mo998
                  Greetings! Anybody have the schematic and boardview for:
                  Lenovo Ideapad 5 14ALC05 82LM
                  FLMA0 LA-J701P REV2.0
                  rev2.0 support AMD Lucienne compared to AMD Renoir in rev1.0.
                  Thank you in advance!
                  06-27-2023, 08:42 AM
                • Nkosikhona
                  X415ma main board rev2.0 schematic & boardview
                  by Nkosikhona
                  Looking for x415ma rev2.0.
                  it is different from rev0.9 and rev3.0
                  does anyone know or have any clue where i can get documentation of 65=aesy4 chip
                  01-13-2025, 11:05 AM
                • infordecima
                  u36sd rev2.1 - chg_en# 0v battery only!
                  by infordecima
                  Good evening, my asus u36sd rev2.1 always has the orange charging LED on when I have the battery inserted, without the charger inserted, without the battery I have chg_en# at 3v everything is fine but when I insert the battery I only have chg_en# to 0v when in reality it should have 3v.
                  b24740
                  help
                  10-14-2024, 04:55 PM
