X415ma main board rev2.0 schematic & boardview
  • Nkosikhona
    • Sep 2023
    • South Africa
    Looking for x415ma rev2.0.
    it is different from rev0.9 and rev3.0
    does anyone know or have any clue where i can get documentation of 65=aesy4 chip
    • 20976
    Richtek 65=
    https://www.badcaps.net/forum/troubl...5-5g-and-5e-5e
    • Nkosikhona
      • Sep 2023
      • South Africa
      Thank you SMDFlea but i failed to specify the code that follows the = sign which makes a difference upon seeing the replies on the forum post you suggested.
      65=AE is the chip documentation i require.
      • veretto
        Only a Member
        • Jun 2019
        • 8
        • argentina
        this maybe can help you.
        • Nkosikhona
          • Sep 2023
          • South Africa
          Thank you Veretto but unfortunately this is not the one i am searching for.
            • 20976
            AE is just the datecode, what matters is the marking 65=
            https://www.badcaps.net/forum/troubl...19#post1482819
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              by JDC
              ONN 100012588
              Long answer:
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
