Asus Q326FA Rev2.0 (UX362F/FA) BIOS
  • nd03
    • Mar 2017
    • 21
    • Romania
    Please I would need the Q326FA REV2.0 Bios cleared. Somehow my laptop I fixed got corrupted and it will not power on display (including backlight).
    This is my current BIOS. It was ok display was coming up while I was debugging something and suddenly it stopped. If it helps the battery indicator blink 4 whites. CPU fan spins. I have VCC Core rails. VCC GT (graphics) not coming up but no short I think Bios is not requesting graphics.
    Laptop Model: UX362F
    Motherboard Q326FA Rev2.0
    There was an issue with intermittent display flicker so I was working on debugging which cable from the display was causing issues (when I played with the cable display came up). Flashed flashlight on display. There is no picture. No backlight. No HDMI. Connecting Keyboard to USB and triggering Caps Lock works so it's POSTING. Not sure what can cause VCC GT and not display except BIOS. I replaced the DRMos for VCC GT rail and it's still the same (0V, 3 Ohms more or less so no short).
    BIOS dump:
    • 22151
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • nd03
      • Mar 2017
      • 21
      • Romania
      I have boardview from this website.
      Some signals from EC:
      ALL_SYSTEM_PWRGD - 3V3
      BUF_PLT_RST# - 3V3 (not resetting)
      LID_SW# - 3V3 (open)
      LCD_BACKOFF# - 3V3 (don't backoff)
      LCD_BACKEN_PCH - 0V (this explains no GPU RAIL I think and no backlight, no clue why).
      LCD_BLEN_CON - 0V (this could explain why no display but then why doesn't HDMI work either???)
      L-BKLTCTL_PCH - 0V (ofc if BACKEN is 0 and blen is 0).
      Do you think this sounds like a Bios issue or maybe I damaged the screen somehow by pulling on the wires?​
    • Andri15
      • Jul 2024
      • 45
      • indonesia
      Re: Asus Q326FA Rev 2.1 ( UX362FA )
      I need give this bios​
      • peste
        • Dec 2016
        • 13793
        • ROMANIA
        read the rules..https://www.badcaps.net/forum/troubl...before-posting
        ​post the original bios of the laptop even if it is corrupted,post the S/N,etc..
        • Andri15
          • Jul 2024
          • 45
          • indonesia
          this is the default file
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            he reads but didn't understand
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
