You think you've seen all the gutless power brick wonders?
  • Behemot
    • 4845
    • CZ
    Missing components? Boring. Half of the board missing here http://www.hardwareinsights.com/foru...2&p=7837#p7837
  • mariushm
    • May 2011
    • 3799
    Re: You think you've seen all the gutless power brick wonders?
    Nothing interesting here.
    They probably made a batch of power supplies using that bigger case, or they bought extra stock from another factory.
    Then, they bodged inside whatever crap psu they had that day recycled from some other devices.. hideous soldering, flux not cleaned from the bottom of the pcbs, they didn't bother to desolder the old wires and just soldered the new cable on the bottom of the board, there's no output filtering as far as I can see which makes me think the psu may have been some kind of "led driver" board...
    • Behemot
      • 4845
      • CZ
      Supposed to be 5 A/12 V for LEDs. But there is Rubycon, ZLH series IIRC as the output filter. As it's been on discount, I think it was more like special edition to rip ppl off. That guy alone sold hundreds of them, other sold more…it's no small batch, they made gazillion of them.
      I can imagine as most of the electronic garbage ends in China, they finally learned a way how to profit more of that than melting into ingots - reuse working components. I bet there are now garage "companies" only making such things.
      • robert
        • Jan 2008
        • 69
        Looks like they re-used the whole PCB from some smaller though fairly high quality brick...
        Actually the best thing they could have done, the transformer looks properly isolated and it might pass EMC, if that ground wire were connected.
        Usually, you get a china-designed PCB with near no creepage/clearance and a transformer with isolation so poor it will break down within the first year. putting 230v on the output.
        • Behemot
          • 4845
          • CZ
          Yeah I think so, I think they got bad boards maybe with bloated caps, put some other caps torn of something else in there and insterted whole board into new casing. The problem is it looks like it is ground referenced when it's just scam and the PE leads to nowhere…
          • robert
            • Jan 2008
            • 69
            Actually that board looks like it was removed from some scrapped name-brand power brick, rated 2 or maybe 2,5A. Too many good quality parts (e.g ceramic fuse) on there.
            The chinese just get a big container of misc. recycled 2-3A power bricks, break open their case and bodge them into their new cases.
            Still, that unit will be much safer even with missing PE connection than 90% of the no-name stuff sold on ebay will ever be.
            Triple insulated secondary wire plus layer isolation vs. plain magnet wire running at >150°C...
            I have bought one of these crappy bricks for analysis, it would only output approx. 60% of its rated power and still run the transformer at around 160°C at 35°C ambient.
            Insulation did break down instantly at <1.5kV (IEC60950 requirement for Class II is 3kV for 60s).
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Doesn't need the egc; the original unit never had one!
              The junkdumpers put the three-wire IEC inlet there to make their shit unit "look better," not hard to figure out...
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • spleenharvester
                GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                by spleenharvester
                I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                07-08-2025, 06:02 PM
              • UADmytro
                Lenovo T14 Gen1 i7 10  nm-C931 (brick)
                by UADmytro
                Hey! I bought a Lenovo T14 Gen1 i7 10 nm-C931 (a brick). The previous owner said he got it on eBay as a password-locked device and took it to a repair service, where they tried flashing something. The result: it doesn't turn on.
                When I plug in the charger, the charging LED lights up, and the power button indicator blinks three times.
                I downloaded the firmware from the official website, but it's incomplete. However, there is a firmware for the embedded controller (MEC1663). I did a mass erase via OpenOCD, wiped MEC1663 along with the EEPROM, and flashed an image from the...
                03-23-2025, 03:45 AM
              • AsusAllyUser
                Asus Rog Ally RC71L-ALLY.Z1X_512 - Smokeless_UMAF "BRICK"
                by AsusAllyUser
                Just another fool that messed with UMAF and bricked their Handheld.
                I ordered a CH341 Programmer and instantly realized i had a problem when the chip was WSON8 form factor.
                I tried using the stock clip connector SOP8 and it wasn't working, i realize most people desolder these chips but im really trying to avoid that.
                I modified the SOP8 so there was pins and it was more of a probe, i have access to the pads. Chat GPT told me this IC was 3.3v but i found one reddit post saying its 1.8v.
                Did i fry my chip with 3.3v when attempting to detect it with neoprogrammer?...
                10-27-2025, 08:04 PM
              • bauto601
                KDM 480W PSU upgrade succes! (opinions?)
                by bauto601
                Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                A "nice" YoungYear unit? - Badcaps
                The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                12-26-2023, 03:05 PM
              • basalisco
                840 g8 brick after flash bios
                by basalisco
                603 / 5.000 Risultati della traduzione
                Risultato di traduzione
                Hi everyone, I had a PC with a password protected bios. I disassembled the bios eeprom, not the rear one (EC), I read it, with the hexadecimal editor I edited it, I rewrote the eeprom, I checked it, I reassembled it and I find the PC in this damned state. I tried reloading the original file but nothing changes. I checked the connections several times, I was very careful with I only noticed that the eeprom when I give the erase command is not deleted neoprogrammer gives me an error as a programmer I used a...
                04-11-2024, 10:50 PM
