840 g8 brick after flash bios
  • basalisco
    • Mar 2024
    • 17
    • Italia
    603 / 5.000 Risultati della traduzione
    Risultato di traduzione
    Hi everyone, I had a PC with a password protected bios. I disassembled the bios eeprom, not the rear one (EC), I read it, with the hexadecimal editor I edited it, I rewrote the eeprom, I checked it, I reassembled it and I find the PC in this damned state. I tried reloading the original file but nothing changes. I checked the connections several times, I was very careful with I only noticed that the eeprom when I give the erase command is not deleted neoprogrammer gives me an error as a programmer I used a ch341, I was very careful with the hot air. I can't explain what happened. Sorry for my English, I hope you can help me​
    • 21907
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • markv81
      Markv
      • 18
      • Netherlands
      Is there no short in the bios chip ? maybe you can check this. I had an elitebook 850 G7 unlocked and when you use HPunlocker or RCunlocker nothing realy changed in the bios. I had to do it manualy. p.s on the elitebook 850 G7 the bios chip was a
      MXIC: MX25L12872F QFN-8 16.384 KB
      • basalisco
        • Mar 2024
        • 17
        • Italia
        You MUST:
        Serial Number: 5CG2386185
        Product Number: 6A3P3AV
        CT Number: PQSNP00WBH51PF
        Description: HP EliteBook 840 G8 Notebook
        build_id: 21WWCVET601#SABZ#DABZ
        Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdpdqeMfPgSguhKj4jhk8mEmVmwn7nVngpDpq.ef
        MAC Address: 38-CA-84-56-77-E5
        MoBO 6050A3426501-MB-A02
        • basalisco
          • Mar 2024
          • 17
          • Italia
          I have already checked the eeprom pins, there is no short circuit
          • rex98
            • Feb 2023
            • 1293
            • Mandaue CEBU, Philippines
            here use BCU to fill your dmi info:
            • basalisco
              • Mar 2024
              • 17
              • Italia
              continues with the same problem as in the video. It's strange as soon as I turn on the power it starts blinking without even turning it on.
              • rex98
                • Feb 2023
                • 1293
                here same procedure
                • basalisco
                  • Mar 2024
                  • 17
                  • Italia
                  here same procedure
                  I'll try it soon. Thank you for your time
                  • basalisco
                    • Mar 2024
                    • 17
                    • Italia
                    here same procedure
                    I don't know how to thank you, it worked!
