SMPS O/P filter inductor selection
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    I require to replace some chokes in PSUes
    What is the best selection method?
    I've seen data that Isat should be greater than Ipeak
    Should I take it as read, Ipk is as shown on the PSU rail spec.?
    Also, should I select the highest inductance as I can afford
    given requirements and form factor?
    For example,
    The first inductors is 8 mm dia and 10mm high
    This is the -5.0V rail on a Enermax PSU
    The rail O/P current states 1.80 A max.
    The second inductor is smaller at 6 mm dia and 8mm high
    This is the +5.0VSB rail on a Chieftec PSU
    The rail O/P current states 2.00 A max.
    So, would it be the case, I select the form factor and
    ensure the saturation current exceed the stated maximum
    and try to get the highest inductance value as is possible
    at a price TBA?
    Any advice appreciated - thanks
  • gonzo0815
    • Feb 2006
    • 1600
    Re: SMPS O/P filter inductor selection
    why do you want to replace them? are they burnt? haven't seen much burnt inductors in ATX PSu`s, where i would have bothered to fix it.
    • JEWilson
      • Sep 2007
      • 369
      They are broken as a result of my poor handling!
      So... need replaced!
      Of course, as they have no markings on them and I do
      not have a inductance meter, I have been looking at Pi Filter calculator applets
      I have the O/P load resistor value for the Enermax (15R) -5.0V rail.
      Caps C1 and C2 respectively, are 470uF 16V and 100uF 35V
      I am a bit hazy on this and have not used filter calcs for many
      years, so some advice would help here
      Thx
      • gonzo0815
        • Feb 2006
        • 1600
        I think your approach seems not that bad, i don“t think that the exact value is critical.
        Only the mag amp inductor (well usually the biggest inductor with more then one winding) is probably a little more important.
        But there i haven`t much clue what it should be.
        • JEWilson
          • Sep 2007
          • 369
          Having done a little research and having used pi filter design calc's
          A synthesis of a pi LC low pass filter can be realised.
          Butterworth, Chebychev and Bessel alignments amongst
          other can be had but these relate to, for example, to RF and
          audio filtration and control freq. response.
          Using inductors in the O/P pi filter for SMPS I believe, is to
          reduce ripple. To this end, it has been suggested, in the
          event an inductor fails, replace it with a wire link but at
          the expense of an increase in the ripple on that rail.
          Also, it has been suggested some flexibilty may be available
          in respect of the L1 and C1, C2 paramters such that, if
          you increase rail capacitance, a smaller form factor and
          in turn, rated inductance can be selected.
          The rule of thumb as suggested, is to ensure the saturation
          current of the inductor exceeds the peak current O/P of
          the rail under investigation and that you should select the
          highest inductance you can afford and of course, phy. form
          factor comes into this.
          Is this an accurate maxim for SMPS O/P rails?
          For the Enermax, I replaced ; the O/P caps with Pana FC some
          time ago. However, I quickly reaslised, post research,
          the fact, the +5.0VSB as well as the -5.0V rail did not have the same
          cap values in positions C1 and C2.
          Probably, due to production issues as opposed to design I surmise.
          For instance, the +5.0VSB rail with a advertised peak O/P current of 1.8 A has;
          1. 1 of 470uF 16V and
          2. 1 of 1000uF 10V
          The -5.0V rail with an advertised peak O/P current of 1.0 A has;
          2. 1 of 100uF 35V
          So, first thing I did was ensure;
          +5.0VSB has 2 of 1000uF 10V
          -5.0V has 2 of 470uF 16V
          As I do not know the inductance in both these rails, I have looked
          at phy. form factor as a guide.
          If I attempted to design a Butterworth low-pass pi filter with C1 and C2
          at 1000uF at the load at 10 ohms, dependant on freq response,
          you would require an inductor of up to 200mH - this inductor would be huge!
          So working at DC with an AC ripple component with OP rail filter considers
          alternative characteristics such as ripple reduction and cost constraints.
          Any thoughts and suggestions advanced, greatly appreciated
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • J_T
            Operating frequency for motherboard common mode inductor/filter
            by J_T
            I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
            The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
            Sorry, I am not experienced hence a basic question.
            01-04-2025, 05:54 AM
          • madan1
            DALI SUB E-12F class D, fluctuating power rail
            by madan1
            Good day everyone.
            I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
            The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
            The normal value of the positive and negative power rails is +/- 43V.
            The positive rail stays...
            10-15-2025, 10:33 AM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            Replaced emmc.
            Terminal log
            UART
            AC_ON
            E-B
            FDE enabled
            06-01-2025, 02:11 AM
          • swerg
            Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
            by swerg
            Hey everyone,
            I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
            I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
            I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
            06-06-2024, 03:39 PM
