Thermaltake ATX supply goes BANG! - TR2 RX-750
  • locojack
    • Nov 2018
    • 4
    • Argentina
    Re: Thermaltake ATX supply goes BANG! - TR2 RX-750
    Does someone have the technical map of this power supply?
    • jazzie366
      • May 2016
      • 304
      Is this not a skid mark around this transistor? I do believe whatever this is has puked it's guts.
      Popcorn.
        • Jul 2011
        • 6040
        Originally posted by bcstedt
        Must be the lighting, I don't see any from here.
        No
        You have a lot of bad soldering joints when you see a ring around the joints those need to be reworked
        I would recommend replacing all capacitors that are less than 100uf
        at a minimum
        It would be better if you replace all the caps except the the main capacitor
        • bcstedt
          • Jun 2011
          • 59
          I had to pack up this project due to moving and am now getting back into the stash. I'm doing some more inspection and measurements and will respond shortly.
          Anyone else have experience with this model PSU or similar?
          Thanks for all the suggestions thus far.
          • bcstedt
            • Jun 2011
            • 59
            Originally posted by everell
            Measure the voltage across the 400 volt input capacitor. If it measures 166 volts, the APFC (active power factor correction) circuit is not working.
            Input cap voltage is 167V.
            • bcstedt
              • Jun 2011
              • 59
              I definitely notice a gap in the solder joint right under R7!
              R7 looks okay to me.
              Originally posted by Behemot
              Also check the input cap for bulging, the top is rounded. May be just the plastic but better be sure.
              Just the plastic insulator on top, all the caps look good (not by brand though, obviously).
              I'm going to check the transistors for shorts and see what shows up.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                It's below R7 and to the right of R6.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • bcstedt
                  • Jun 2011
                  • 59
                  Yeah that's a shadow, little dip in the solder.
                  • bcstedt
                    • Jun 2011
                    • 59
                    Found some shorts!
                    Q7, Q8
                    D7, D?
                    • bcstedt
                      • Jun 2011
                      • 59
                      Well, I found some of the bang! Looks like R9 spilled it's guts because ... ?
                      • bcstedt
                        • Jun 2011
                        • 59
                        ... Q5 and Q6 are shorted. 6R190C6
                          • 31065
                          and q5 & 6 are driven by what?
                          that has to be checked next
                          • bcstedt
                            • Jun 2011
                            • 59
                            Driven by CM6800G!
                            Any thoughts on replacing the 6r190c6 with 20N60C3 or FCP20N60 (ON Semi) or ... ? I'm searching for details on issues or reliability related to these FETs and found a few situations where these substitutions were made. Also, in one review of this PSU they show the 20N60C3 instead of the 6r190c6.
                            Just curious.
                            • Behemot
                              • 4845
                              • CZ
                              #34
                              Yeah me thinks IPx60R190C6 and 20N60 look like equivalents.
                              Think that 500V FET should be fine as well, it's two-forward when it has CM6800 without even looking, and most of them usually only had 18N50s (or 20N50s when over 600 W). Depends on what you can find around.
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                              • shamsudeen
                                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                by shamsudeen
                                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                07-19-2025, 07:14 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
