Enermax EG251P-V with low 12v rails
  • Agent24
    I see dead caps
    • Oct 2007
    • 4924
    • New Zealand
    Picked up an old case for free (using it for my in-progress HTPC ) until I get a proper one
    It came with an old enermax PSU - "hey this could be good" I thought...
    Not wanting to risk anything, even on an enermax I decided to take a look inside, nothing seemed amiss, in fact I spotted a couple of rubycons in there
    I proceeded to hook up an old (80MB) hard drive for loading and started it up. no smoke or fireworks, but 12v was sitting at 11.04 and the hard drive just didn't seem to be able to spin up fast enough to actually get going.
    Checked the other rails which all seemed fine, but -12v was way out at -8.6v
    Now nothing is visually wrong, all caps *look* fine (though we all know that can mean nothing) - on second look though, not all of them are rubycons for some reason... some are CTC (I think is the brand)
    Any ideas on what would cause this otherwise good PSU to act in such a manner? the caps perhaps, or could it be something else?
    -David VanHorn
  • starfury1
    • May 2006
    • 1256
    Re: Enermax EG251P-V with low 12v rails
    CTC arn't what you would call great caps I dont think, even the liberties use them for DC output
    one person killed them off in a year in a liberty, although I think he might have been giving it a good work out, still
    So if they are being use for output get rid of them....
    I have no idea of how that one put together so at a bit of a loss
    could find now pics on that model here (strange he says)
    Find a few on a google image search but not much use
    best I could see was 339 Quad op amp
    not that I think -12 is used at all these days but mostly I think it done with a 3 terminal regulator -12 rail
    If you can post some pics for reference.
    but more then likely someone here will know the beast
    and will offer better input then I
    Enermax dont build what you would call exceptionally bad supplies
    so its probably worth the time to see if you can get it going properly.
    it sound to me like possibly some controller regulation issue a recap my fix it I just don't know
    not the guru here.
    HTH cheers
    Hey..... how did you go with the other thing ?
    (that I've totally forgotten what it was but remembers you posting on caps ?...maybe you already replied?)
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • Agent24
      I see dead caps
      • Oct 2007
      • 4924
      • New Zealand
      I'm running my main computer on a liberty ELT400AWT I bought 2 years ago, it's still running perfectly - let's hope it stays that way
      I thought it was only the newer ones that had issues anyway?
      But back to the PSU in question - I've attached a photo, hopefully it shows what you were interested in, if you want me to take anything more specific, just say.
      Bottom right is your LM339, top right is LM3905 which regulates the -5v rail which is taken directly from -12, and in turn comes off of the 12v at some point, it seems.
      voltage reading from the output of the +12v rectifier (STPR1020CF) showed 10v, which is probably not helpful to the state of things. Can't get a reading on the input (maybe i'm doing it wrong?)
      Yeah I posted here a while ago about 2 soltek boards that wouldn't start, and had leaky GSCs.. still haven't actually got around to doing anything with them but I'll hopefully be able to start on those next week...
      -David VanHorn
      • gonzo0815
        • Feb 2006
        • 1600
        I think you may need more load at the 5v & 3.3v rail. Those PSs are group regulated, thus if there is no load at the low voltage rails, 12v will stay low.
        A HDD is not considered a load of any meaning for the 5v rail.
        Apart from that, if -12v is important for your setup, just check voltage before the -12v linear regulator. If it is is in the range of a little higher then -12v just replace the VR.
        But sure, CTC caps can fore sure go ape shit.
        • starfury1
          • May 2006
          • 1256
          actually did find some pic here but no idea of the page language think Japanese
          http://chronos.mentai.org/2001/d010805_2.htm
          Japanese English translation
          http://translate.google.com/translat...hl=en&ie=UTF-8
          here what it says on the -12V
          - 12V and 5V-output terminal of the three-laden drive from奴. SECの型番はKA7905。 KA7905 model of the SEC.
          here is a link to the pdf on the TOP210PFI
          KA 3842A
          not sure how all this slots together but there is some info for you
          HTH
          Cheers
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            is this measured or via some onboard monitor?
            remember +12 will be low with little/no load on +5
            • starfury1
              • May 2006
              • 1256
              are thanks Gonzo
              Edit... you too KC8
              you have both posted wjile I was in the middle of doing mine...like last 3 Hr between things
              • Agent24
                I see dead caps
                • Oct 2007
                • 4924
                • New Zealand
                I am an idiot.
                I think you're completely right, I retested it with 3 hard drives and a motherboard, +12v and -12v were both sitting happily @ 12.01v
                Honestly though, I have never seen any PSU that did this before. I've run a lot with the only load being my voltmeter and they've all been fine. suppose I should remember this for next time - and here I was thinking there was something faulty with an enermax ...
                Well, if you guys reckon CTC are junk I guess I should get rid of them if I plan to use this PSU... which is likely
                -David VanHorn
                • starfury1
                  • May 2006
                  • 1256
                  I should have thought of that,
                  I was going to mention the relationship between rails
                  totally missed the load aspect thought with your post Doh!
                  If your going to replace the caps use quality stuff
                  you dont need to use the super low ESR (VRM type like ruby MCZ's)
                  but low ESR like Panasonic FC series. Ruby ZL etc
                  (some are water basic electrolytes like FM, not to reopen that one
                  but water based caps dont handle the heat as good is the discussion argument whatever, they will still work thought)
                  you got an RS components or Farnells near you locality, you can order from?
                  Yanz did a table somewhere but I cant find it
                  here his version 1 crude dummy loads for loading a psu
                  https://www.badcaps.net/forum/showthread.php?t=2400
                  I suppose it depends on how much of a workout its had and how much you intend to give it but check the fans OK too
                  Gee just re reading my first post whoa spelling mistakes everywhere...
                  so many disruptions to day
                  not a good day to try and help me thinks
                  HTH anyway
                  Cheers
                  • starfury1
                    • May 2006
                    • 1256
                    OH and THANKS for the Nice big photo too
                    OH again
                    Szie of caps (diameter pitch height) as in getting the little beggers to sit flush you have to watch out for too.
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      "If it ain`t broken, don`t fix" it or similar comes to mind. So i think if the PSU does well leave the ugly CTC in there.
                      But sure, having some nice capacitors inside a PSU does not hurt either ;-)
                      Personally i am am somehow obsessive with capacitor replacement, so it certainly would not hurt to get some nice capacitors inside this Enermax.
                      • starfury1
                        • May 2006
                        • 1256
                        TRUE!
                        I really have to agree with that but sometimes especially if you dont want to have to strip something down later you break the cardinal rule and hope it dont BITE you!
                        I think you mention PVR use
                        if it was me I would in that case, put a decent quality fan in and look at the best possible way to shut the fan up while still getting good air flow...also I would make some sort of air filters up for the case...don't know if you can buy something like that in a case suitable for PVR use
                        you probably want to put it in a cabinet somewhere all hooked up so are probably not wanting to have to tear it down to often I guess
                        try to keep the dust bunnies down.
                        Cheers
                        • skwarszczow
                          Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                          by skwarszczow
                          This is my first post on the forum
                          I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                          Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                          Before completing the purchase, we decided to erase...
                          03-23-2025, 06:04 PM
                        • SarcasticOP
                          General question about MacBook power rails for repair.
                          by SarcasticOP
                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                          • PPBUS_G3H (12.6V-12.8V)
                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                          • PP3V42_G3H (3.42V)
                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                          • PPVRTC_G3H (3.3V)
                            • This
                          12-12-2024, 05:50 PM
                        • Cemal Odabasioglu
                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                          by Cemal Odabasioglu
                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                          Observations...
                          01-14-2025, 03:54 PM
                        • ferah831208
                          help with AMD Ryzen 5 7535hs power rails
                          by ferah831208
                          Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.
                          03-09-2025, 01:59 AM
                        • DrewPhillips
                          SFX PSU - Need High Current on 3.3V & 5V Rails?
                          by DrewPhillips
                          I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
                          The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
                          02-18-2025, 01:03 PM
