Upgrading Silverstone SX600-G PSU Caps
    • 31247
    Re: Upgrading Silverstone SX600-G PSU Caps
    your caplist has no diameters.
    • Behemot
      • 4845
      • CZ
      Why would you do that with the Rubycon?
      Yeah I guess I'll leave this one be to favour or your local stores as for 2200/16 I only got 10x30 mm at the moment. And as for 6.3 I got some 20mm samples, 2700, but it is not worth dripping into multiple orders for you.
      As for Chemi-Con range, have a look after KYB, KZN, KZH, KZM series, those have best energy density and being latest series, longest rated lifetime. Rubycon and Nichicon does not yet have anything comparable, Panasonic maybe those FR.
      stj: diameters are pretty obvious. Taicon is 12,5. Bigger SC D10, smaller&SH D8. The smallest will be D5.
      • bokecan
        • Dec 2015
        • 14
        I thought I was supposed to leave the Rubycon? I just removed a little bit of the white goo that was next to it and holding in place a thin plastic sheet. I thought I could leave the Rubycon and just add some more white goo and the sheet to keep it like it was, but maybe I'm mistaken and misunderstood on the Rubycon.
        Sorry about the lack of diameters, didn't occur to me at first that I should add those, but I see now how that could be helpful information. I can add if needed.
        Okay, so in regards to the stock you have, it sounds like you don't have the ones I'll need for all of them? I would still be glad to buy what you do have as I really appreciate all the help. I'll try and find the others in the Chemi-Con series that you have recommended as it sounds like they will be the only source for some of them.
        If there is anything else I'm missing just let me know. Thanks
        • Behemot
          • 4845
          • CZ
          Well I don't understand what do you want to do with that cap, just leave it be in peace
          You got Digikey in there, most likely Farnell too. Not sure about the geolocation of all these companies…maybe RS components or distrelec too.
          • bokecan
            • Dec 2015
            • 14
            Ahh, okay. Yes, sorry for the misunderstanding. I'm not going to touch the Rubycon, I'm going to leave it there.
            Thanks for all the help and information. I will update as I make progress on the project.
            • bokecan
              • Dec 2015
              • 14
              Here is what I've found searching around for replacements. These are all Chemi-con, and in stock at Mouser. These look like the right ones? I've matched the voltage, capacitance, and size, and went through and found the longest life available in either 105c or 125c versions.
              [2]
              Height= 16.5mm (Can be a little taller if need be)
              A3TC
              1500uf
              6.3v
              SC105c
              http://www.mouser.com/ProductDetail/...IPiddQYEV%252b
              [3]
              A3TC
              1500uf
              6.3v
              SC105c
              [Yellow Circle]
              Height= 26.6mm (Can't be taller)
              Taicon
              1425A(m)
              2200uf
              16v
              105c(pw)p
              http://www.mouser.com/ProductDetail/...RnfFDUaA%3d%3d
              [Blue Circle]
              Height= 10mm (Really close to coil, could maybe be taller)
              A3TC
              220uf
              16v
              SC105c
              http://www.mouser.com/ProductDetail/...XS1Td8SvI02myq
              [Red Circle]
              Height= 14.6mm (Real close to coil, could maybe be taller)
              470uf
              25v
              SH105c
              http://www.mouser.com/ProductDetail/...bMDGHJUP6uGVyM
              [Green Circle]
              A3TC
              1500uf
              6.3v
              SC105c
              [Orange Circle]
              Height= 10mm (Can be taller)
              10uf
              50v
              SS105c
              http://www.mouser.com/ProductDetail/...167eVm9Bdhc%3d
              • Behemot
                • 4845
                • CZ
                #27
                I think that you can replace the 220/16 with for example KZM 470/16. It will be just OK. These high-temperature caps usually have higher ESR, they are more for automotive.
                • bokecan
                  • Dec 2015
                  • 14
                  Ahh, okay. Thanks for that. I will do a little more digging and see what I find.
                  One thing I wasn't completely sure on was in regards to ripple and ESR. If I understand correctly from what I've read, it's okay to have a cap that's rated higher in ripple than the one it's replacing. As far as ESR goes though ideally I want low-ESR caps because of the application being a power supply? Or am I not understanding that correctly?
                  • Behemot
                    • 4845
                    • CZ
                    #29
                    Generally, yes. Usually close to the original. It is not so important to strictly keep the dogmatics abour ESR always same or lower, in SMPS usually capacity/ripple current playes greater role. If you are within reasonable range to original, it will be OK. There are different series from Chemi-Con now, KZN have great ripple current while higher ESR. I think KZH have lowest ESR but not that high RC and life.
                    But often different factors are important too (like how fast is the cap to respond on the ripple, which is also function of above parameters). If they count with it in the design, they may use very low ESR caps, today mostly polymer caps. Makes sense especially for synchronnous rectification. But those have lower capacity so they are often combined with wet electrolytics. Polymers are generaly fine, with few exceptions (Lelon), that's why we only swap wet electrolytics.
                    • bokecan
                      • Dec 2015
                      • 14
                      I found a KZM for the 220uf 16v one. I reviewed the other ones and it looks like they are all listed as low impedance, and have higher endurance/hour life.
                      So my plan is to buy all of these from Mouser, since they are all in stock, then I'll get them in and start swapping. I'm still working on the fan, I tinkered around with a low profile 92mm unit and did get it to fit, but only with removing the plug and line in section. So I'm not exactly sure how I'm going to approach that part just yet.
                      I have a feeling that whatever fan setup I come up with is going to be run off the motherboard, with it's own custom fan curve in the BIOS. The controller inside the PSU is not capable of running a 12V fan apparently, and I don't like the idea of the fan sitting their idle and not running at all, I guess I just don't understand that logic of not having the fan run at all. I know it's for noise, but it still seems like it should run slowly at a bare minimum.
                      • Ingram
                        • Sep 2016
                        • 5
                        • Estonia
                        #31
                        Bringing up an old topic, but might be useful as a followup.
                        The unit I have, had a noisy fan and later from reviews I found that this has a questionable choice of capacitors, I was curious to find a replacement for those.
                        Heres the details so far I have for my unit.
                        The difference with OP is that NCC was changed to Rubycon and Taicon to Teapo. Looking for replacements for Teapos now, assuming the Rubycons are OK. Any thoughts on Suncon (pic)?
                        However I think there is another capacitor that reviewers and OP missed and that is between the daughterboard with fan controller below white/blue blob in the middle-back part of the board. I'll have to desolder it to find out what it is. It looks like a small black Teapo, but I can't see any numbers due to whatever is coating it.
                        Also another question, there are aluminium caps with red text (pic, behind electrolytic, on the daughterboard), with three lines of numbers:
                        330 or 380
                        16CP
                        562
                        I couldn't figure out what these are, perhaps someone can comment?
                          • 31247
                          red text are polymer caps.
                          • Behemot
                            • 4845
                            • CZ
                            #33
                            Look like Teapo CP.
                            • Ingram
                              • Sep 2016
                              • 5
                              • Estonia
                              #34
                              Figured out what the unknown cap was. Rubycon 35V 100uF ZLH 3M1505 105C PET underneath a piece of heatshrink.
                              • Ingram
                                • Sep 2016
                                • 5
                                • Estonia
                                #35
                                Since I need to order from Mouser anyway, I also checked caps from there. Luckily OP-s choice is still relevant.
                                Here is what I came up with
                                https://docs.google.com/spreadsheets...it?usp=sharing
                                I also went with KZM for 220uF, however I figured that for 470uF a better fit in terms of the diameter would be KZN instead of KYB. One probably can fit a 10mm cap there but it will be tight. Rest is the same. Should be good, right?
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  Got everything but "F" column on stock. For less than half they ask from expensivouser.
                                  • Ingram
                                    • Sep 2016
                                    • 5
                                    • Estonia
                                    #37
                                    Do you have anything comparable to the "F" column? It's out of stock in Mouser as well.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      It is D8 right? I just received 470/50 but those are D12.5. IIRC it is on the -12 V rail, regulator input so the chances are there will really be voltage lower than -16 V. Smallest usable I have is D10x20 mm, KYB 1000/25.
                                      • Ingram
                                        • Sep 2016
                                        • 5
                                        • Estonia
                                        #39
                                        It is D8 indeed. D12.5 will be definitely too big, whereas D10 will be tight, touching a heatsink.
                                        Meanwhile, I found replacements for the out-of-stock ones from Panasonic FR series.
                                        • ChaosLegionnaire
                                          HC Overclocker
                                          • Jul 2012
                                          • 3266
                                          • Singapore
                                          #40
                                          Originally posted by Ingram
                                          assuming the Rubycons are OK. Any thoughts on Suncon?
                                          rubycons are fine. they can stay. the suncon is fine as well. its actually a sanyo cap.
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • eryjus
                                            by eryjus
                                            05-10-2023, 11:21 AM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • Foetuss
                                            Gigabyte GA-6OXT :: caps question
                                            by Foetuss
                                            Good evening
                                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                            But I was also suprised about the bigger boys, which are 330µF 25V.
                                            Could it be they used 25V caps because they were cheaper / available at that time?...
                                            02-11-2025, 12:22 PM
