AT Power supply: how turn-on?
  • zgouki
    • Mar 2008
    • 7
    Hi everybody!
    I´m a rookie in the world of electronics and also in terms of english languaje, I´m not american, so my english is soo poor .
    I have a AT power suply with this especification:
    TOUCH ELECTRONICS CO.,LTD.
    Model Nº: SP9627
    FIC Part Nº: 71-50324-00
    I investigated and this PSU gives 50W.
    This AT PSU don´t have any switch to turn on, only have the molex and the mothers-output an three outputs (violet,grey and black) that I don´t know for what are usefull.
    I need to turn on this power supply to use it in my electronics experiments
    I hope that you will understand me and I ´m waiting yours replies!
    Thankas and see ya!
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: AT Power supply: how turn-on?
    Welcome zgouki.
    Japlitic posted a picture of your psu: perhaps he knows the switch cables' color. Quite strange there isn't a proper switch or, at least, two big cable with a connector.
    Zandrax
    Have an happy life.
    • zgouki
      • Mar 2008
      • 7
      Ok, I saw this picture in this forum (attachment). I think that the cables (3) in the circle green in the second picture are the turn-on cables but I don´t know how conect bought....
      One of them is GND becuse is black, but the grey and the violet????
      Thanks for your reply.
      • starfury1
        • May 2006
        • 1256
        doh posted but not supply I was thinking of
        You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
        • davmax
          • Dec 2005
          • 899
          If I remember correctly these old power supplies had a mechanical toggle switch on the front panel. If one lead is earth I suspect the the other two leads are intended to go to a switch that just connects them together to switch on the power supply.
          Would anybody like to check me out on that?
          Gigabyte EP45-DS3L Ultra Reliable (Power saver)
          Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
          160Gb WD SATAII Server grade
          Nvidia 8500GT 256Mb
          160Gb WD eSATAII Server grade for backup.
          Samsung 18x DVD writer
          Pioneer 16x DVD writer + 6x Dual layer
          33 way card reader
          Windows XP Pro SP3
          Thermaltake Matrix case with 430W Silent Power
          17" Benq FP737s LCD monitor
          HP Officejet Pro K5300 with refillable tanks
          • zgouki
            • Mar 2008
            • 7
            I think the same that davmax,
            But I didn´t connect anything because I don´t what will happen.... (EXPLOSION!!! )
            • kikkoman
              • Jul 2007
              • 691
              the few standard AT PSUs I can remember had a 2xON push switch (going to the front panel via a 4-lead cable) that directly switched both A/C lines, thus no standby mode.
              can't see such a cable here, the A/C jack seems to go straight to the PCB. there's a grey block underneath the A/C jacks - could that be a relais?
              "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                What kikkoman said is what I remember.
                Usually there was a 2P2T switch with 4 wires.
                Hot and Neutral were both switched.
                Ground stopped at PSU and did not go to switch.
                There were some with a switch inside the PSU that was activated by a rod that passed through the case to the front panel 'button'.
                Mann-Made Global Warming.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  2P2T ??? or 1P2T ??? Been too long...
                  See picture.
                  - Dr Seuss
                  • kikkoman
                    • Jul 2007
                    • 691
                    2P1T, effectively. i think it was a 2P2T switch, but only single throw used.
                    • zgouki
                      • Mar 2008
                      • 7
                      So what I must do?
                      The out-cables of the PSU are the molex, this cables :
                      HTML Code:
                      http://pinouts.ru/Power/MotherboardPower_pinout.shtml
                      and the 3 cables (black,grey,violet) that are also conect in the motherboard.
                      I have the motherboard, I turned on the cpu when I pressed one of the 3 microswitch there are in a PCB with 3 indicators-leds. This PCB have cables were conected to the motherboard to, but in other position.
                      i don´t know what another information i can give you for this problem.
                      • starfury1
                        • May 2006
                        • 1256
                        link
                        no comment on the above supply...no idea...
                        I do I think remember what you guys are talking about...it just dont seem the case with that one to me.
                        (it was switching 240/120VAC & Neutral and they were spade connectors to a DPST (DPDT) )
                        ..but I could be wrong
                        the photo is too small and from what I can tell like kikkoman I cant see mains wires going out
                        no help I know
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Okay, first it's not an AT power supply.
                          It's some proprietary (custom) unit.
                          This page:
                          http://www.a1parts.com/surplus/index.html
                          ... Says "Has 3-prong power on/off connector."
                          That connector probably connects to the front panel in what ever it is for.
                          Here:
                          http://www.cnczone.com/forums/archiv...p/t-39748.html
                          ericdwilso said:
                          ""There is a 3 position connector for the power switch... I jumpered a pair of the terminals and that started the PSU.""
                          ... Unfortunately he does not mention WHICH pins.
                          It is made by this company:
                          http://www.luminapower.com/contact.php
                          They make custom power supplies.
                          The FIC Part Number tells me this is something made for FIC.
                          (I am guessing that FIC = First International Computer".)
                          The way that is wired it is unlikely AC goes to the on/off connector.
                          It is probably DC that trips a relay (or transistor).
                          Yes, Black is probably ground.
                          Connecting one of the other two (grey or violet) to the ground should start it...
                          BUT!
                          BUT!
                          BUT!
                          - I don't know if it's supposed to be a momentary contact or a true on/off switch.
                          The other wire many be intended for a front panel LED or light to tell you it is on -or- for a reset switch. (Just guessing.)
                          - Dr Seuss
                          • starfury1
                            • May 2006
                            • 1256
                            figured it was a proprietary build job,
                            thats why I wasn't even game to suggest anything
                            Nice detective work Bonez regardless
                            Cheers
                            • davmax
                              • Dec 2005
                              • 899
                              Based on the detective work. There are two possibilities
                              1. The three wires are involved with low voltage DC to switch ON the PS.
                              2. That AC power is controlled by connecting two wires voilet and grey.
                              It would be a hazard to connect the two wires without first measuring what voltage exists on them when power is connected to the PS.
                              Carefully measure what voltages exist on the voilet and grey wires using the black wire as the common. Then we might be able to determine what to do.
                              Nvidia 8500GT 256Mb
                              33 way card reader
                              Windows XP Pro SP3
                              • zgouki
                                • Mar 2008
                                • 7
                                Firts of all, I wanna to thanks to everybody who help me in this topic. I´m really grateful for yours replies!
                                Finally I coud turn on the PSU ! PCBONEZ and davmax are in correct: I tested with a multimeter (PSU connected to the AC line previously)the grey cable and the violet with the GND (black) cable, and these are the results (all the voltages are DC):
                                ¦ O ¦ <---- Grey : + 2,87V...........................................................
                                ¦ O ¦ <---- Violet : + 5 V.............................................................
                                ¦ O ¦ <---- Black : GND................................................................
                                When I put this female connector in the respective male in the mother board I tested with the multimeter again, and this is the 2nd result:
                                ¦ O ¦ <---- Grey : + 5 V...........................................................
                                Then I press the micro-switch in the external PCB, the PSU turn on and this is the 3rd result:
                                ¦ O ¦ <---- Grey : ??? V...........................................................
                                Why "??? V" ? Because when I want to test with the multimeter the wires Grey-Black, the LCD say: 0.00 V. Then when I want to test with the multimeter Grey-Violet, I don´t have time to see what the LCD say because the PSU turn off!
                                But don´t worrie, I finally hit the nail on the head...when grey and violet are connect, the PSU is off; when grey and black are connect the PSU is on, so I should buy an interruptor with 3 pins/2 positions like this:
                                Any advice will be appreciated. Thanks and good bye buddies!
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  There are dozens (or even hundreds) of different ways they can do this using IC's, transistors (as switches), or even mechanical relays but the basic idea is the same.
                                  Changing the state (voltage) at one pin causes the state to change at another pin or pins.
                                  By what you have shown for voltages when the grey wire is grounded the PSU starts.
                                  When you tested Grey-Violet you put +5v back on the grey wire from violet wire (through the meter) and that turned the PSU back off.
                                  Drawing is not a real circuit but should help with understanding the basic idea.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I think this maybe closer to what you have.
                                    NOT FOR SURE! - I can't see it!!
                                    The 2.87v you measured on the grey wire may just be leakage through an IC chips circuits.
                                    - Dr Seuss
                                    • zgouki
                                      • Mar 2008
                                      • 7
                                      Hi again. I´m trying to put this circuit in the PSU...is OK or no?
                                      The led is a blue led and the resistor= 150 ohms. The switch is the same that a told you before.
                                      Sorry, I thanks you for yours replies but I don´t understand what do you told me in the lastes post.
                                      I wanna a simply solution like the mine, but I don´t know if is gonna works or not.
                                      See you and thanks again
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        That should work if we have guessed the circuit correctly.
                                        - Dr Seuss
