Xantrex Powersouce 1800 Overloading (Error E03)
  • jojo69
    • Nov 2015
    • 25
    • US
    Re: Xantrex Powersouce 1800 Overloading (Error E03)
    exactly budm!
    OP needs a SERIOUS source of nominal 12VDC to even approach this unit's rating
    I suspect if he did build a huge battery bank to run the thing for any length of time he would also have to address supplemental cooling for the inverter as it is clearly only intended to run for a few minutes with the original battery.
    • Behemot
      • 4845
      • CZ
      I think that 80+ Ah battery would be enough for that…those have strong screw terminals, they can handle 200 A no problem…
      • jojo69
        • Nov 2015
        • 25
        • US
        for a few minutes...yeah
        • smorg
          • Oct 2015
          • 18
          Very interesting observations, thank you very much!
          Guess it's running normally and I'll just have to find other backup solutions for the furnace & water pump.
          Thanks again!
          • Behemot
            • 4845
            • CZ
            80Ah battery will work for at least quarter hour at 200 A.
              Looking at those RED and BLACK wires from the batteries, they sure look under rated.
              • CapLeaker
                Leaking Member
                • 8118
                This isn't proper wiring between the battery and the inverter to start with. That's not going to work for too long and not working good at all under heavy loads. Fix that cabling. You really want to put reliable 200A through that?
                • Borse2008
                  Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                  by Borse2008
                  Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                  I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                  • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                  • There’s
                  07-15-2025, 04:55 AM
                • Green Probe
                  Mosfet Advice
                  by Green Probe
                  Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                  05-22-2025, 10:49 AM
                • user234
                  Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                  by user234
                  Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                  My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                  I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                  If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                  This is...
                  05-10-2025, 04:25 AM
                • artvandalai
                  Advice on rewiring this stepup transformer?
                  by artvandalai
                  I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
                  01-14-2025, 01:00 AM
                • wattsRpower
                  MBP 820-00928a need advice
                  by wattsRpower
                  I'm working on an a1707 macbook pro for a friend of mine that said it had stopped working and will not turn back on. After opening up the laptop I discovered a short on C7382 which took the PPBUS_HS_CPU to gorund.
                  After fixing the cap issue, I had 12.6 volts on the line. Not sure what or when something happened, but I am now getting 3.6 to 3.8 volts fluctuating. I was taking some volt readings and I'm not sure if I shorted something or if something else has happened.
                  At this point, I'm not sure where to start looking for something to fix. Maybe the cpu fried anyway when the PPBUS_HS_CPU...
                  10-12-2024, 04:55 PM
