Need help repair dead AVF brand power supply
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    #41
    Re: Need help repair dead AVF brand power supply
    Originally posted by momaka
    As for the input electrolytic caps: 2x 330 uF will limit you to about 200 Watts, 2x 470 uF to about 250 Watts, 2x 680 uF to 300-350 Watts, and 2x 820 uF and above for 400+ Watts.
    does that statement only apply specifically to that psu design or to all psus in general? cuz i have an enermax liberty 500w and fsp amacrox 500w and both have one 330uF 400v primaries. and i dont think those "branded" psus were bullsheeting on the power ratings...
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      #42
      Primaries in APFC PSUs store far more energy than primaries in non-APFC PSUs, because there's roughly ~385V going across an APFC primary compared to the ~170V going across the primaries in the voltage doubler.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #43
        Yes, that applies to all switchmode PSUs.
        However, perhaps I should have been more specific. Note that in my above statement, I listed the capacity as 2x ### uF. But I forgot to say that this is when you have two 200V caps in series - which is often the case with cheaper, older, and usually non-APFC PSUs (there are some APFC PSUs that have 2x 200V caps in series instead of a single 400V or 450V, but it is rare).
        When you have two equal capacitors in series, the total capacitance becomes half, but they can handle two times the voltage of each cap's rating. Thus, 2x 200V 330 uF caps in series will have 165 uF total capacitance and will be able to handle up to 400V DC.
        With your Enermax and FSP PSUs, they already have 400V/450V caps, so the capacity you see is the actual capacity. A single 330uF 400v primary cap will be able to store approximately the same power as 2x 680 uF 200V caps in series.
        Hope that clears it up a little now.
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
          by sam_sam_sam
          I was working on this CNC machine today found no keyboard functioning no control relay powering on
          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
          Found shorted diodes on main controller relays there are 3 of them that...
          01-07-2023, 05:43 PM
