Re: No boot and random shutdown
I dont know with those psu's how or what you might be looking for but the PG sig does have a limit range and there is a circuit for it at lest in the older TL494 types
I thing max is 500mS (ATX spec) but most are around 350mS
it used to be build around a quad op amp.
The above is if memory serves me correctly
Since your voltages are a bit low I am incline to think this may be some kind of indicator that as pcbonez has said something drifted out of tolerance.
I have known of smaller value caps to fail
and one supply I had years ago would not start while plugged into mains...I had to unplug it...in that case it was a dry joint on a resistor
I have no idea what the resistor was for and can only summarize it had something to do with some sort of discharge or reset or flip flop action in the psu.
once soldered it was fine...
so guess you looking for something more subtle as the fault and possibly heat related
lower value caps around controller or were ever the PG line goes might possibly be a good stating point.
but not necessarily the real fault, semi's as you say have been known to go leaky resistors high in value etc and joints faulty
so this one may lead you a merry chase.
since there is 2 posted with very similar fault descriptions it possibly does have a common cause.
anyway just my thoughts and I could be wrong
cheers
cheers
