No boot and random shutdown
  • starfury1
    • May 2006
    • 1256
    Re: No boot and random shutdown
    I dont know with those psu's how or what you might be looking for but the PG sig does have a limit range and there is a circuit for it at lest in the older TL494 types
    I thing max is 500mS (ATX spec) but most are around 350mS
    it used to be build around a quad op amp.
    The above is if memory serves me correctly
    Since your voltages are a bit low I am incline to think this may be some kind of indicator that as pcbonez has said something drifted out of tolerance.
    I have known of smaller value caps to fail
    and one supply I had years ago would not start while plugged into mains...I had to unplug it...in that case it was a dry joint on a resistor
    I have no idea what the resistor was for and can only summarize it had something to do with some sort of discharge or reset or flip flop action in the psu.
    once soldered it was fine...
    so guess you looking for something more subtle as the fault and possibly heat related
    lower value caps around controller or were ever the PG line goes might possibly be a good stating point.
    but not necessarily the real fault, semi's as you say have been known to go leaky resistors high in value etc and joints faulty
    so this one may lead you a merry chase.
    since there is 2 posted with very similar fault descriptions it possibly does have a common cause.
    anyway just my thoughts and I could be wrong
    cheers
    • starfury1
      • May 2006
      • 1256
      Sound like you got some idea what your doing with electronics so
      if you really want to rap your head around something maybe this will give you food for thought.
      older stuff so you probably going to have to work it out to what you got
      http://www.repairfaq.org/sam/smpsfaq.htm
      http://www.pavouk.org/hw/en_atxps.html
      no answer but might twig you to something
      HTH
      cheers
      • Andreasbest
        Dell G5 SE 5505 Random boot loop
        by Andreasbest
        Hello.
        I bought a G5 for my self, at a low price, i knew it was faulty, so the fault is that does random boot loops.
        I tried RTC reset, BIOS update, replaced thermal paste with MX-5, checked fans for dirt, disconnected all flex cables (daughterboard usb, keyboard, trackpad, wifi, m.2, replaced RAM) but still the same.
        This behavior can be a faulty GPU/CPU or if any of these components get faulty the laptop shut down completely?
        When i get luck and enter Windows i see everything in device manager without exclamation marks.
        Any advices or thoughts welcomed...
        08-20-2024, 07:41 AM
      • privato89
        Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
        by privato89
        I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
        Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
        Let's begin:
        Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
        03-26-2024, 06:37 AM
      • hinisa
        Xiaomi router freezes at boot after re-capping
        by hinisa
        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
        07-08-2023, 05:58 AM
      • Luke Anders
        Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
        by Luke Anders
        A few details about the laptop itself:
        Name: Lenovo Legion 5
        Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
        BIOS Version: GKCN60WW
        EC Version: GKEC65WW
        Serial Number: PF39AQ7Z
        Board Model: NM-D562 Rev 3.0
        RAM: 16GB Installed, DDR4 (brand new)
        NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
        I bought this laptop recently from eBay as a faulty device....
        10-12-2024, 05:13 AM
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
