Re: Help replacing 4 diodes with rectifier and improving old AT PSU
Doesn't any SMPS create interference? Switchers are very noisy when operating, I would install the input filtering components.
List the uF of the filtering caps used in this unit and we can compare their specs to a suitable series
JPCE-TUR: https://cdn.badcaps-static.com/pdfs/...7336c19519.pdf
You should replace _ALL_ caps. Not just those on the secondary side. Also the caps between those two heatsinks...
You may only keep the primary caps. Besides them, you should replace anything else.
And as mentioned: you should replace the original caps with something equivalent. So if they used general purpose caps, you also should use general purpose caps...
Do _N O T_ use Low ESR or Low Impedance caps on those units. That might not be a great idea...Last edited by Stefan Payne; 08-02-2015, 10:43 AM.Leave a comment:
I would not stick such low-ESR caps as FR/FC into two decades old PSU, but stj does not know anything else than that. Remember than the best at those times were not even Chemi-Con LXZ which were used on motherboards. Many years later the ultra-low ESR caps arrived, those went on MB and the previous best went into PSUs. Who knows what especially FR would do in there.
Chemi-Con KYA and Samxon RS I have are much more suitable for that.Leave a comment:
that's nice, but it means nothing for internal equipment wiring.
there are other non-standard "standards" too i see a lot.
for example, building wiring.
red for switched live, yellow for unswitched.
very common when i see light fittings with integral battery backup.Leave a comment:
http://www.openelectrical.org/wiki/i...le_Colour_CodeLeave a comment:
What color code? Black/white??? You're kidding.
So all the EU-spec supplies were China-pride Deers and other such junk? Wasn't the standard in GB, for single-phase, red for hot, black for neutral, and green w/yellow stripe for bond/ground/EGC?
Why does this strike such a nerve with you?! How come, before "brown/blue" became standard, did a legit power supply for international markets not use black/white?
Where do you get the idea that the intended load is what determines switching freq? There are constraints based on topology (full/half bridge, forward converter, flyback), transformer/inductor core, wire size, losses in O/P rectifiers and BJTs/MOSFETs. But other than accomodating those limitations, the load in no way "dictates" the switching freq, in computer, or any other SMPS.
With that out of the way, why don't you address the issue of filtering? If I believe your story (which I don't), how come that PCB is marked for those filtering components, rather than having alternate silkscreens for "different capacities?"
You and I know damn well that those inductors are often replaced with jumpers in deers, etc, for cheepness.
firstly i never related load to frequency, i related AGE to frequency.
old psu's often ran 30-50khz, modern ones run 70-200khz.
second, i'v never even seen a "Deer" other than in a park.
the worst pc psu's i'v had are CodeGen and those go directly to the bin.
i work mostly in industrial equipment and if you think SONY, TDK, Delta etc dont use white & black you need to expand your horizons beyond shitty $10 pc supplies.Last edited by stj; 07-31-2015, 06:43 AM.Leave a comment:
"they dont usually have pie filters because such designs wont work well at lower frequency's."
I was referring to this comment regarding to the pi filter and low frequency, it works just fine when you design it for the frequency you are dealing with.
I grew up and worked with tube equipment for a long time and nothing wrong with pi filter at low frequency.
In the really old day of tube radios and TVs they that choke of the pi filter as part of the speaker that does not use permanent magnet, it uses that choke as electomagnet in place of the permanent magnet.Last edited by budm; 07-31-2015, 12:23 AM.Leave a comment:
I was referring to the O/P side, but even at power-line freq, both pi filters (well regulated supplies, even tube equipment) and common-mode filters are/have been used.
What color code? Black/white??? You're kidding.Originally posted by stjshows how much you know.
ALL psu's sold in europe up until recently used that colour code even if it aws a $1000 sgi supply or a top-brand pc one.
most still do.
I'm surprised that you, of all people, never mentioned this: "duh, let's put black&white wires in our fake export supplies- them dum'mericans will never know the difference." If what you state above is true, then everything in the world is black or white...
Black and red, FYI, are both colors for hot in 120/240V, and 208V systems. Brown, that's a hot in a 480/277 system, and blue is third phase for 208. Uh-oh! Brown and blue??? Phase A from a 480 bank to phase C of a 208 bank? NEC violated, call Mike Holt and Joe Tedesco!Originally posted by stjmaybe you would prefer black & red, or brown & blue,
I've heard it all before...Originally posted by stjthe wire colours do NOT indicate build quality or intended market.
You can't make such a broad generalization. And for the record, early deer ATX supplies just had the 5VSB board above the main PCB, straddling (and attached to) the heatsinks. Remote on/off was just pulling the deadtime control pin of the 494 to max deadtime for "soft off." IOW, an AT supply by any other name.Originally posted by stjone other thing, AT supplies oscillate at much lower frequency's - they dont usually have pie filters because such designs wont work well at lower frequency's.
Don't do an SMPS apples and oranges with me, comparing a line-freq supply such as this:
to the pi section at the output of an SMPS, citing "huge inductors" as the reason for leaving them out.
You and I know damn well that those inductors are often replaced with jumpers in deers, etc, for cheepness.Last edited by kaboom; 07-30-2015, 11:57 PM.Leave a comment:
i was refering to the outputs, but at lower frequency's the filters need larger cores so unless you want huge coils ( and i do have a couple with them) it's not really viable.
the ones i have with output coils are not AT/ATX form factor, they are huge.Leave a comment:
But pi filters have been used in 60 Hz 120Hz power supplies output filters for decades, that is LOW frequency.
Or are you referring to the pi filter at the AC side?Last edited by budm; 07-30-2015, 10:24 PM.Leave a comment:
most still do.
maybe you would prefer black & red, or brown & blue, or just pink for the LGBT assholes.
one other thing, AT supplies oscillate at much lower frequency's - they dont usually have pie filters because such designs wont work well at lower frequency's.Last edited by stj; 07-30-2015, 10:17 PM.Leave a comment:
Are you shittin me!?
The filter was left out for cheepness and you know it. I'll bet that thing also had black/white line/neutral wires, since it looks like one intended to be dumped in the US.
How come after I put a Sony 9W (9v, 1A) SMPS wallwart into a bigger enclosure for someone, and added an actual line filter, conducted RFI was zip ten feet from the supply cord?
Your idea is preposterous. Even the "widdle baby" SMPSes in printers have the filters. I personally know of a Deer that spewed trash all the way up into the FM BCB- 88-108 MHz, let alone HF. You could hear the birdies between strong stations, weak ones were wiped out.
Then it would state different values or ampacities for said filter components, not omit them completely, you antecrep double!!! Do you see the filter components marked as optional on that PCB?!
Next, I suppose you'll try to tell us that the Pi-choke, on the output side, is "optional depending on wattage."
Remove the output caps, and enjoy the squarewave; you can't integrate the trapezoid coming from the output inductor without the filter caps!!!!
Get it right or stay home, imposter.Last edited by kaboom; 07-30-2015, 09:56 PM.Leave a comment:
one pcb, mutiple ratings of supply.
the 200w one may have not had filters while the 250w one that pushed the transformer harder would have had them.Leave a comment:
Really?!
I can't see it doing anything besides that...
First, PSes had full input filtering. Then cheapies/fakes took it out, because they were cheap.
Now, you mean to tell me/us that all these (originally) POS power supplies were individually tested, and those specific ones creating RFI/EMI, were pulled from the lot and had filtering added?!
I don't buy that story; in fact, I don't even rent it.
Keropi, I'd transplant the parts from that filter PCB, putting the X-cap at C1...Leave a comment:
allrighty then! I'll do just that with a small change: nippon chemi-con caps instead of panasonic ones: I can't get another quality brand here other than chemicon (tbh I can't complain because the other alternative is LeLon caps....)
thanks again for all the help!Leave a comment:
no, if the psu caused interferance then the parts would have been fitted originally.
i'v done a number of AT supplies, one just a few days back.
i just do a full recap with pansonic FR & FC and change the fan.
well that and add a power switch inplace of the power outlet.Leave a comment:
Thank you all so much for the suggestions/help, seems like the diodes will remain in place.
There isn't any problem with them , I just thought a bridge rectifier would be better to have.
What about input filtering? Do you think I should bother installing missing components?Leave a comment:
I still wouldn't replace them with a single-package bridge. Discrete diodes can dissipate heat faster. If there is a heat problem a bridge isn't likely to to help.Leave a comment:
changing the rectifier diodes on that board? pointless... unless they are bad or there is a heat problem...Leave a comment:
just change all the caps for panasonic FR or FC
the diodes were good enough when it was new - if the board isnt darker under them then they arent heating up.
filters? who needs filters!!Leave a comment:
by DvsrHi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
After replacing the caps I started testing out the speaker. It seemed...4 Photos-
09-10-2025, 10:20 AM -
by _AcE_I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
There's no physical damage... -
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
by momakaFor today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
http://www.rmac.kingwin.com/products.../abt_650MM.asp
I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
What mostly drew me into buying it is its 2x PCI-E power connectors... -
by momakaThis one should make @Pentium4 smile
(if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
Macron Power Technology Co. LTD.
Let’s look at the PSU itself.
The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of... - Loading...
