LED Reading Lamp - meltdown in driver compartment
  • gintama
    • Sep 2007
    • 59
    I'm looking to ID this part on the board from an LED lamp:
    The structural ribbing in the lamp housing is blackened above where the component was sitting. Guessing the PCB should have been fastened on an angle to keep the hot bits away from the plastic. The copper discs in the background are capacitive pads for the controls, which now glitch out to varying degrees.
    From the duplicity of the PCB (there are two strings of LEDs, warm/cool, only one of which works now) I believe the trashed part is the same as the one on the upper circuit, marked with L4611 / 3360 but no visible brand marking:
    Could it be this regulator? Integrated Silicon Solution Inc IS31LT3360-SDLS3-TR @ Digikey
    The caps look OK, the two UNITED pieces are 12v 25uF, and the more upright one is a Cheng 16v 100uF.
    The lamp was from Costco and looks identical this AliExpress item:
    http://www.aliexpress.com/item/Free-...345778571.html
  • CapLeaker
    Leaking Member
    • 8147
    Re: LED Reading Lamp - meltdown in driver compartment
    it very well could be the LED driver. That also explains why one set is working and not the other in your case.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      looks like you found the part.
      its cheap enough to try it.
      hopefully the cob didnt get damaged.
      some drivers blow up if leds open up.using diode test on dvm test the ones in the dead string.they will light dimly if good.one that doesnt light is bad.
      • gintama
        • Sep 2007
        • 59
        Thanks for that kc8adu, wish I would have seen it sooner. I got the replacement driver and new caps, and eventually got them wired in after bypassing the broken PCB traces. The second set of LEDs came on, but this also resulted in the initial symptoms (capacitive control buttons misbehaving) to return. Figuring the cause was the black blobbed IC and therefore irreparable, I pulled the newly installed driver and wired a switch onto the other output to select either the warm or cool lights. This worked great for about 45 seconds... Then the lamp abruptly ceased functioning, and that was the end of that.
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • howardc64
          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
          by howardc64
          Problem
          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
          Model & Board Pics
          Conflicting Spec
          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
          https://www.shopjimmy.com/vizio-gj-2k1...
          10-10-2024, 01:16 PM
        • charif
          Audio Driver for Thomson P14C4BK128
          by charif
          Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
          I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
          The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
          Here are the details:
          • Model: Thomson P14C4BK128
          • Operating System: Windows 10 64-bit
          If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
          Thanks in advance for your help!
          04-30-2025, 05:41 PM
        • bohaboha
          how to install gl usb2.0 uvc camera device driver on windows 10
          by bohaboha
          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
          any help?
          01-26-2025, 08:33 PM
        • vestaviascott
          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
          by vestaviascott
          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
          Here's what happens:
          1) Power on
          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
          3) Blue status light flashes for appx 4 minutes...
          07-29-2020, 06:08 AM
