Adapters Voltages?
  • ivtec
    • Dec 2008
    • 1967
    Adapters Voltages?
    Hi guys; can you tell me what is the correct load Voltage on a Power Adapter,
    for example i have here an DC 3v 200 ma power adapter when i test it on my Fluke it reads about 7v,without load, is this bad?
    i rarely find a Power adapter that reeds the exact voltage that is in the adapter specs always have 2 to 3 volts or more more,what is too much voltage?
    Re: Adapters Voltages?
    The linear non regulated power supply will show higher Voltage without the load, it should be 3V with 200mA load, without the load the output can as much as 50% higher, but in your case, your meter may have bad batteries or way out of calibration.
    • ivtec
      • Dec 2008
      • 1967
      Thanks budm, but i measured with another meter and it shows same v,
      if you say without load it can be 50% more, then it's only 1 volt over .
        "DC 3v 200 ma power adapter when i test it on my Fluke it reads about 7v" 3V to 7V that is way more than 50%.
        3V, so 50% higher will be 4.5V, you are getting 7V.
        • pc7fan
          • Aug 2013
          • 52
          Once I had a 12V 500mA wall wart and unloaded it was reading around 28V (but with a 24 ohm resistor - 500 mA load), it was ±10% of the labeled 12 volt rating.
            If that is the case I hope it has 50VDC rating caps in that wall wart.
            To get 28V the cap is charged up to the peak of the transformer Voltage, so in this case the transformer AC is around 28V *0.707 = 19.796V!
            • Behemot
              • 4845
              • CZ
              That is pretty normal situation for wall transformers and usually the smaller the transistor, the higher the no-load voltage which than drops drastically with load. Not sure where you took that 50 % from, that is no general rule…often it is that way, often not.
                "the higher the no-load voltage which than drops drastically with load. Not sure where you took that 50 % from" from taking apart 100's of 100's of wall warts for failure analysis, beside if they design the wall wart with such high output impedance they will have to use higher Voltage cap rating.
                Also if the device being power by this wall wart and only drawing 80% of rated current for head room purpose, the supply Voltage will be way too high for the device.
                "Once I had a 12V 500mA wall wart and unloaded it was reading around 28V (but with a 24 ohm resistor - 500 mA load), it was ±10% of the labeled 12 volt rating." Just think about this, what Voltage will be feeding the device if it is only drawing 100mA or less in standby mode? Will you want to use this wall wart?
                • Behemot
                  • 4845
                  • CZ
                  Most devices have DC-DC inside today and for battery chargers, it is actually intention as the voltage slowly rises above nominal (charged batteries always have more than nominal).
                  BTW I am talking about 50/60Hz transformers, are we on the same subject here?
                    "BTW I am talking about 50/60Hz transformers, are we on the same subject here?" Yep, simple linear power supply with iron core transformers, with simple bridge and filter cap, not regulated output.
                    28V no load and 12V full load, that is the worst transformer regulation factor I have ever heard of, no load of 1.8 factor (no load is 80% higher than full load) spec is about the worst I ever run into.
                    http://carroll-meynell.com/technical-transformer
                    • Behemot
                      • 4845
                      • CZ
                      Small 3-5V ones often have 6-9 V…
                        Worst case factor of 1.8:
                        3V * 1.8 = 5.4V
                        5V * 1.8 = 9V
                        12V:28V = 2.33 factor, very bad transformer.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • Instafixx
                          Macbook A2179 820-01958
                          by Instafixx
                          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                          I checked the Power Sequences below and found this -
                          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                          05-20-2023, 05:19 AM
                        • bimole
                          Weird behavior on 3.3V rail of a CORSAIR CX600
                          by bimole
                          A colleague gave me an apparently ill CORSAIR CX600.
                          He told me that he heard a banging noise, and smelt the magic smoke.
                          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                          It's another story on the 3.3V rail...
                          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                          02-13-2025, 04:49 AM
                        • AJ847.63e
                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                          by AJ847.63e
                          Hi Folks,
                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                          05-06-2025, 10:37 PM
                        • electron_jj
                          Panasonic TH-L42D25A checking the PSU output voltage
                          by electron_jj
                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                          08-29-2021, 08:13 AM
