Napa 12V/6V battery charger
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Today, where I was at for a cookout, I encountered a battery charger that had red wires on the inside of the housing fried.
    But, check this out, it actually looked like it had connectors in the wrong places.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    Re: Napa 12V/6V battery charger
    I do not get your drawing, where is the rectifier? and what are those straight thick black lines?
    May be good clear pictures of the unit?
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Darn it! I didn't have my camera...
      For some reason I couldn't see the bridge rectifier and I believe there's zero filtering caps for the DC output! (AC hum heard in starter when powering up the starter of a riding lawn mower engine)
      And the charging mode dial appears to just change which windings to connect to on the transformer. The transformer is large.
      Where I said WTF is where I saw a connector blade of a red wire touch one for a black wire and thus appeared to connect with something unrelated.
      Arc A770 16 GB
        • 31055
        i'v seen a lot of old car battery chargers that only used a rectifier & fuse - no caps.
        the battery is a giant cap - so i suppose if there is no electronics to drive then they dont care.
        • japlytic
          • Oct 2005
          • 2086
          Such chargers are pulse chargers which deliver its maximum current peak at the highest positive and negative peaks of the AC waveform, which helps prevent the battery from gaseous reactions.
            +1, Full wave bridge will give 120Hz charging pulse, no filter cap needed.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              My guess at the drawing is that the charger is a multi-winding primary, center tapped, multiple parallel output secondary. There is a 2-diode fullwave bridge depicted as a twig at the top of the "transformer" box...
              But yes better picture needed :-p This was only a guess...
              Then again this is atypical. There is usually a bit of regulation but that's definitely not clear from the picture...
                NVDC charger configuration...
                11-05-2024, 03:28 PM
                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                Narrow VDC applications where the system power source is
                either the battery pack or the regulated output of the charger.
                This makes the max voltage to the system equal to the max
                battery voltage instead of the max adapter voltage. Operating
                at lower system voltage can improve...
                11-05-2024, 04:43 PM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
                Bauer tool battery pack charging with a HERCULES charger modification
                by sam_sam_sam
                The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                05-06-2023, 12:17 PM
