Troubleshooting AC/DC circuit board
  • soyuppy
    replied
    Re: Troubleshooting AC/DC circuit board
    There's a chip on board next to BD1. I assume this is the Bridge Rectifier?
    Testing this with ohm meter setting at 200ohm. Tried to test all for legs and couldn't get any reading out it.
    Could this be the culprit?
  • soyuppy
    replied
    i'm a bit in experience when it comes to visual inspection. But I just tried resolder the crack as shown in the red circle. Doesn't do it...still same problem.
    Which component is the bridge rectifier? There are several IC chips, can any of these be the culprit? Is there way to test for these?
    replied
    check for cracked soldering like in the circle.
  • soyuppy
    replied
    yes 160VDC is measured but only the radial caps was replace didn't know about the other that need to be replaced. which one are they? do u think they are bad as well?
    replied
    So you do have 160VDC between the two legs of the main filter cap?
    And you also replace that small lytics start-up/running cap in the primary side?
  • soyuppy
    replied
    pics with new caps
  • soyuppy
    replied
    no, I have 3 boards that have the same problem. Right now just focusing on getting one board working. So I have all the caps replace on this one board that has good fuse.
    replied
    So did you also replace the fuse?
  • soyuppy
    replied
    Back with updates.
    Got all the caps replaces with Panasonic FR series. Match each new cap with the same spec as old one.
    But still not getting any power output on both lead.
    Any other suggestion where to trouble shoot.
    I've been reading a lot on switch power circuit. Most point out that sometime noise would generated from rectifier.
    But it's not the case here. The PSU is dead silent.
  • ben7
    replied
    Originally posted by soyuppy
    when red lead touch black lead, show zero.
    When red lead touch top of fuse and black lead touch bottom of fuse, show 1.
    So, 1 means it is reading an open-circuit?
    P.S., Would be helpful if you would just say that it measures open-circuit, because saying that it shows "1" is confusing.
    Before you replace the fuse and try to power it on again, you should check the AC input rectifier bridge to see if it is still OK. And check the main switching transistor (in this case, it is built-in to the switching IC, but it still should be testable) for a short as well.
    And, also, next time you try to power it on again, put a 40W incandescent lightbulb in series with the AC input. This will limit the current, and can help prevent things from frying again, if there is still a problem in the circuit (or your probe slips and shorts something out, etc...).
    -Ben
  • soyuppy
    replied
    what does you meter show when you touch both leads together?
  • vinceroger69
    replied
  • soyuppy
    replied
    Originally posted by budm
    So the fuse is fine then.
    May be I'm confused on what shorts.
    But fused is tested on Ohm reading. It shows open(1) on meter. So fused is blown. Need to be replaced.
    replied
    yep...did that...and yes, it's shorts.
  • soyuppy
    replied
    Fuse is a short circuit device, so just measure it with Ohm meter (no power applied), it should show as shorts, same resistance as when you touch your meter probes together.
    replied
  • soyuppy
    replied
    Originally posted by ben7
    The fuse on the PSU might be blown as well now too. It's covered in some black heat shrink tubing.
    Thanks for the info. Yes, there's black heatsink tube right next to the main entrance. And removing the heatsink show indeed a fuse. It's pretty small and hard to tell that's its short...but I'm pretty sure it's short.
    But I'm more interest in how to remove/replace this fuse. From the look of it, I should be able just remove the fuse leaving the lead join on the board. But seems like the top cap are glued into the fuse. Try to wiggle for movement, but doesn't budge.
    Do I have to remove the entire housing from the board as well?
  • ben7
    replied
    I was probing the caps...and then it just sparkle. Wasn't sure what it was...until i see the black charred. I decided to disconnect and kind of don't want to do anything else now
    Will re-soldering cover the trace burn out? If I resolder and reconnect, how do I tell/test if transformer still operating? can I read it off volt meter? there's a lot of lead wire onto the board...wasn't sure which wire to tap on the volt meter.
  • soyuppy
    replied
    replied
    It looks like the trace burnt open. Did that location make contact with other conductor or something while you were probing the board?
    But looking closer I can see that the pin has bad solder joint, so you can try fixing that connection and resolder all the pins of the transformer as well.
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
    by sam_sam_sam
    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
    12-16-2023, 08:39 PM
  • repair-it
    Engineering help - how does the charging circuit on this board work?
    by repair-it
    This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
    08-31-2024, 12:32 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
