Imac 24 PSU Liteon PA-3241-02A
  • darjness
    • Nov 2012
    • 31
    • Portugal
    My imac died, wont turn on, only 3 leds on, first i tough that motherboard died, but after some search on internet i found that psu tend to fail on those imac aswell. Mofset 060n03lg was shorted, i replaced it, also i replaced all 2200uF 16v caps, but mac still wont power on, fans twitch when i plug the power cord and also when i press the power button. Hdd spins, but if i have many thing running in house like heaters very quickly shuts off, if not it keeps on for long.
    Any tips what it cloud be ?
    Thx
  • darjness
    • Nov 2012
    • 31
    • Portugal
    Re: Imac 24 PSU Liteon PA-3241-02A
    New mofset 060n03lg has drain and source shorted, is that normal ?
      No, you need to remove it off the board and test it off the board again.
      • darjness
        • Nov 2012
        • 31
        • Portugal
        I just removed it. pin 2 and 3 are shorted both ways
          Shorted power MOSFET should have caused the fuse to blow also, plus the IC that drive the Gate of the MOSFET may be damaged also.
          • darjness
            • Nov 2012
            • 31
            • Portugal
            I tested voltage without the mosfet. With mac off i get 12v on drain, 0v on source and gate, with mac on i get 12v on drain, 21.8v on gate and 2.8v on source
              Right now I have no idea what the function of that shorted out MOSFET is yet, it is may be part of the SMPS, the PFC, or it may be using as a switch. The connections on the board will have to be traced out to find out.
              • darjness
                • Nov 2012
                • 31
                • Portugal
                Source goes to 3 pins that go to the motherboard, Gate comes from somewhere psu and only have voltage when mac is on, drain comes from +12v that also goes to motherboard and its always on. on mofset schematics its says Fast switching MOSFET for SMPS
                  It sounds like it is being used as a switch to provide Voltage to pin 3 of the connector.
                  You may want to check pin 3 and Ground to see if there is very low resistance treading that may have caused current over load and took out the MOSFET.
                  • darjness
                    • Nov 2012
                    • 31
                    • Portugal
                    I tested it, multimeter beeps for half a second than goes to 1 , theres a 470uf 16v capacitor on ground and those 3 pins, pins number are 8 9 10 ,
                    • darjness
                      • Nov 2012
                      • 31
                      • Portugal
                      Could it be that i bought a bad mosfet ? When i got it i was so excited that i would have my imac up and running that i did not test it before install, since new one is bad also now, i ordered more 5,
                        So the original one was shorted and now the new one is also shorted out?
                        • darjness
                          • Nov 2012
                          • 31
                          • Portugal
                          Yes, the original is shorted on all 3 fets, the new one source and drain are shorted and 59 ohm's on drain and gate
                            That is strange to have Drain to Gate damaged also.
                            • darjness
                              • Nov 2012
                              • 31
                              • Portugal
                              I think the best thing to do now is to wait till monday, when i receive those new mosfets, and than i will test it before install. I found that the problem is this mosfet after searching the net and bad caps forums, they fail very often and most of times psu runs after replacement, also chinese replacement psu´s looks on pictures like they replace this mosfet only and sell them.
                              • darjness
                                • Nov 2012
                                • 31
                                • Portugal
                                I found now the old one and tested it again and it has 20 ohm's on drain and gate
                                • darjness
                                  • Nov 2012
                                  • 31
                                  • Portugal
                                  Hey,
                                  Mosfet arrived, tested first good values, soldered to pcb,tested mosfet again and all good, power in,voltages are good, power mac on, fans twitch and 3 leds, I power the mac off test mosfet again and its shorted.
                                  Any tips what could be the issue ?
                                  Thx
                                  • domas
                                    News Hater
                                    • May 2013
                                    • 323
                                    • Denmark
                                    something on the output partially shorted/leaky?
                                    • darjness
                                      • Nov 2012
                                      • 31
                                      • Portugal
                                      I cant find anything shorted and nothing is leaky , Maybe something shorting on motherboard when turned on ?
                                      • domas
                                        News Hater
                                        • May 2013
                                        • 323
                                        • Denmark
                                        i wouldn't say so.
                                        It would trip the OC protection IMHO.
                                        You mentioned that it does work fine for few minutes. So turn it on without the mb and check all the rails for out of tolerance voltage. Including low power -12 and the like (not sure what imac voltages are)
                                        if they all are fine, try plugging it to mb starting the computer and check which ones are out of tolerance. But limit the time for that as it will bur again.
                                        I had a psu where i shorted -12 rectifier and was unable to spot it as it was under a big choke. It did not have oc protection and it would burn the primaries upon the start up.
                                        • MikeCebula
                                          Apple 24" iMac A1225 Liteon PA-3241-02A1 schematic and boardview
                                          by MikeCebula
                                          Request schematic and possibly boardview for Apple 24" iMac A1225 Liteon PA-3241-02A1
                                          Thank you,
                                          Mike
                                          11-04-2023, 10:18 PM
                                        • Siverian
                                          LITEON PA-3241-02A1 PSU iMac 2009
                                          by Siverian
                                          I've faced a problem that my iMac does not start anymore. After a short investigation, I've found that PSU does not work and does not produce any stand-by voltage.
                                          With a DMM I've found a short on 24V line and the problem was in Schottky diode D200. Another issue that I've found is a broken n-FET on a 12V line. After removing these components the short has disappeared. I replaced the diode witр a 30CTQ060 and transistor with another n-FET (I did not have exactly the same transistor). Now PPS works fine without load on the output.
                                          10-07-2021, 09:19 AM
                                        • ryogadan78
                                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                          by ryogadan78
                                          Hi guys, I need your help again.
                                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                          06-10-2025, 03:49 AM
                                        • Stephen
                                          iMac M1 DFU restore issue
                                          by Stephen
                                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                          this is the message it gives me with the error
                                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                          03-07-2025, 12:19 PM
                                        • Stephen
                                          iMac 27” 2020 Boot issue
                                          by Stephen
                                          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                          08-16-2024, 09:32 AM
