The best Sun Pro you've ever seen
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Double forward, with huge heatsinks and good silicon. Currently trying to get the 5VSB to not run so hot. There's that 21Ω resistor on the bottom side and 33Ω on the top. Without the bottom one, the 5VSB runs at 8.45V I'll upload more pics later
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: The best Sun Pro you've ever seen
    The primary uses two Fairchild 9N90C FET's on the primary. The label claims 450W, which seems pretty honest. It looks to have two 12V rails with OCP. Controller on the secondary is PS222S https://cdn.badcaps-static.com/pdfs/...ec01b02f46.pdf
    There is a Texas Instruments TL3843P on the primary. Uses an 80mm fan for intake and 120mm for exhaust. All caps were Canicon/CS/JEE/GL. Only one CS cap and two GL caps. The 2200uF 6.3V CS cap failed on the 3.3V after the coil. I think for two reasons: It was physically touching the -12V output rectifier, and it was 8mmx20mm. Seems small, must be GP (No series printed on it) The only other caps that failed was the 100uF 10V JEE on the -5V rail, and both 4700uF 10V Canicon on the 5V filtering. I was blown away that both 3300uF 16V JEE on the 12V filtering were okay. They tested 3367uF 0.02Ω and 3412uF 0.02Ω. Those caps I put in are 30mm tall, so look how big that those toroids are! The heatsinks are huge too.
    I can't get the 5VSB to run correctly without the original 5VSB resistors, which seems odd to me. However, I had to replace the 5VSB output inductor, because a leg fell off the original one when removing, because it got so hot!
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      Strange. Did you change 5vSB caps?
      Idiotic design if it does so.
        • 31090
        the clearance between the fuse, thermister and the nearby low votage stuff is way to low!!
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Seems like Sun Pro is definitely picking up a little - or at least in terms of components sizes. That output inductor is definitely ginormous !
          However, the quality of the craftsmanship (if you can call it that) still looks poor. They really need to start paying their workers a bit more.
          8.45V!?!? That's a motherboard killer right there, or at least a competitor for the 250W Bestec 12E. Either Sun Pro seriously messed up on the design here -OR- something went wrong during manufacturing.
          The 5VSB should be at most 5.25V without those two resistors. Is it a 2-transistor design or something else? Any suspicious caps near the 5VSB circuit?
          I agree. May want to add a plastic sheet to separate them or something.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            I did. I changed the original 1000uF 10V GL with 1000uF 10V nichicon PW, and changed the 330uF 10V JEE with 1000uF 10V nichicon PW.
            True. Although, I did move the thermistor to get a better view of the 5VSB.
            Yeah, mainly the soldering side. I'll take a solder shot, but I've already redone a lot of the joints.
            Yeah, and it ran at 5.74V when the computer was running. The lowest it's got was with a single 47Ω resistor. I'll try it with none and see what it does. Otherwise, I may have to do a everell style mod. Yes, it is 2 transistor.
              • 31090
              dying opto-isolator?
              does it use a 431 ?
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Oh boy! Get the dim incandescent bulb tester ready! I still think it's a little early for 4th of July fireworks
                Yeah, stj is on the right track - try a new 431 shunt and new optocoupler. Look for a critical cap too. Or perhaps the small 5VSB transistor on the primary driving the large 5VSB transistor is open or shorted?
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Replaced the opto and TL431, even though they both tested good. It was doing the same thing. No critical cap in this design.
                  I tried with no resistor, and the voltage was all over the place, between 6.97 and 7.4V. So I tried something that I knew would probably be a bad idea, but I wanted to see if it would do what I thought it would, and it did. I installed just a 5Ω resistor, and the voltage was a stable 5.06V, but the resistor melted the heatshrink around it in about 20 seconds
                    • 31090
                    any non-electrolytic caps in the circuit?
                    specially film types?
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Just ceramic
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        I guess try the optocoupler next. Before that, though (since you have the 5VSB transformer out), pull the small 5VSB transistor that drives the bigger 5VSB transistor on the heatsink. Check its B-C and B-E diode properties. If okay, put it back in and then try a new opto.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          I had already replaced the optoisolator
                          Are you talking about the one to the left of "J22" ? I think it's a 945. I'll check tomorrow. The 431 I replaced is U9
                          • прямо
                            Viper22A 5VSB circuit
                            by прямо
                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                            01-13-2024, 07:05 PM
                          • kotel studios
                            FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                            by kotel studios
                            Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                            Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                            I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                            Any ideas where to go next?
                            02-23-2025, 11:47 AM
                          • mrcliem
                            CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                            by mrcliem
                            Hello...
                            I got my self a dead CM V700 PSU, with nothing on +5vsb
                            I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                            As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                            The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                            I have read the datasheet and and still can not...
                            06-29-2023, 08:18 AM
                          • socketa
                            Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                            by socketa
                            Rescued this one
                            Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                            Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                            The 5VSB drops to 2.5V when it 'shuts down'
                            And the voltage across the primary cap falls from 335V to 330V at the same moment
                            I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                            12-20-2022, 03:06 AM
                          • hobostove
                            Corsair RM1000e - Help identify 5VSB Zener diode
                            by hobostove
                            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                            There's a 22ohm resistor that's melted and open, but it still has the bands.
                            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                            It looks like the diode connects the source and drain of a TNY284...
                            03-27-2025, 02:25 PM
