What are the 2 POTS for?
    I am looking into an old PSU of mine, old delta atx 300W-KB1.
    I remembered that calibration of the pots are possible for the various voltages.
    I found 2 here, Pots-A for the 12v+5v, but I dont know what is the POTS-B?
    Not 3.3(fixed), not the 12v nor 5v using the 2nd pots.
    Anyone knows?
    Thanks!
    Re: What are the 2 POTS for?
    adjustment for the fan ramp-up temp?
      Could be for current limiting protection or overvolt protection.. or almost anything to be honest.
        Trace the circuit to see what the pot's connected to, or, just leave it as-is, if the PSU works ok there is no need to adjust it?
          This PSU does not use fan-rpm-management.
          I checked on the voltage again, this POTS-B seems to control a voltage between 2 to 4 volts. It leads into a LM339D chip.
          Not sure what it does, but is it to control the PS-ON or PWR-ON signal?
          <- reading atx spec-sheet
            Suspect it's part of the OVP shutdown circuit, unless you had a very light -> no load and this was shutting PSU off, it is best left at it's present adjustment.
