Truepower 2.0 recap and repair
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Truepower 2.0 recap and repair
    What did you end up using in place of the 4700uF and 3300uF caps?
    Mann-Made Global Warming.
    - Dr Seuss
    • Krankshaft
      • Jan 2007
      • 2328
      I personally was able to use the original 4700 caps they were 12.5 Pana FC series.
      It took some coaxing but they were within 3mms of the board and the PSU is fine.
      • Krankshaft
        • Jan 2007
        • 2328
        Ok if you want this PSU working here is a blow by blow on what to check.
        I recently repaired my D-Link Wireless B routers switching PSU using this method. It turned out in that case the PWM IC was dead.
        Lets assume for a minute that the transformers are fine since most likely they are.
        Check the input capacitors and rectifier.
        Is voltage present at the primary switching MOSFET?
        Check the Mosfet with the diode checker.
        Check all of the secondary diodes with the diode checker (they will be on the heatsink near the secondary caps) are they fine?
        Do you have 5 volts on the standby wire?
        If not check the standby supplies PWM IC, Mosfet, and Rectifier.
        Check for pulses out of the standby PWM to the gate of the standby FET.
        This supply may combine the PWM and FET into one package or they may combine the main and standby supplies into one PWM IC.
        To find out which look up the ICs at alldatasheet to see what they do.
        Do you have voltage on the green (PS ON) wire?
        If not check the PWM IC.
        • Kaine
          • Mar 2007
          • 55
          #64
          agreed
          all caps have been replaced with new ones except primary caps, which i have little reason to suspect beyond being FUs. I could replace them but would rather not unless absolutely necessary.
          I'm trying to avoid live testing at the moment. I'm game only if you can tell me exactly what setting my multi should be on and where i should stick my probes. I'm pretty cautious about live testing for various reasons.
          Which mosfet? so far every one i've looked at checks out ok
          Remember that one of the original, immediately obvious problems with this psu was a diode that had failed (in fine style, too) all others in the area check out. I only have limited access to components and i am sick to death of taking components in and out.
          no.
          correct me if i'm wrong but won't this require a CRO? because i don't have one. Working with basic kit here, Multimeter functions only please.
          I've got a fine collection of data sheets going but i certainly don't have all of the components... some of them i can't get close enough to see part numbers because of how crowded the board is.
          I have no activity at the motherboard plug at all.
          Assuming i can find it, how do i check it?
          • asr
            Finding replacement diode iPad Pro 3rd gen A1701
            by asr
            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
            07-09-2024, 06:24 PM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
          • NicRac
            monowheel repair,Is the diode the problem?
            by NicRac
            Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
            First of all, I am new here. Therefore I will shortly introduce myself.
            I am Nico and currently I study Physics.
            In my freetime I like to build and repair stuff. Especially big battery's.
            A few years ago I got myself an electric unicycle, monowheel or however you call that.
            The battery bms was broken so I replaced and resolder that. Nothing big.
            I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
            07-26-2024, 06:13 AM
          • Topcat
            4700uF 6.3v and 3300uF 16v in a 10mm Diameter
            by Topcat
            Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
            10-14-2020, 06:35 PM
          • dennis_elx33
            NO BODY MARKING Diode
            by dennis_elx33
            Hello Everyone,
            I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
            While compared to the reading of another diode from the next channel it won't read at reverse bias.
            Now the problem is; it does not have any body marking.
            So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
            What do you think is this diode?
            Can you please suggest what part number can i use to replace this faulty diode instead?
            Hoping that you...
            06-14-2024, 12:36 AM
