Hi, I recently bought a XFX 750W power supply which returned because it was so loud and unbearable. So i need help finding a reliable PSU with atleast 750W for around £60. I want one that will last me years (just like my ocz 500W psu did with teapo caps) without trouble and it has to have a quiet fan. if anyone can find one in a retail store in the uk that will be even better. what are your suggestions for a psu, thanks
Need help finding a PSU
Tags: None
Re: Need help finding a PSU
my ocz psu is quiet even near full load and its full of dust. but im upgrading my graphics card soon and il need a bigger psuComment
Only have a single graphics card? What CPU? I haven't been catching up with the latest and greatest stuff, but I doubt you will need a new PSU just for a graphics card upgrade. Most CPUs today peak at 100-120ish Watts and graphics cards maybe just as much for the high end ones.Comment
that ocz will be enough when you upgrade. but I highly recommend cleaning out all the dust thoroughly and replacing those junk caps. its a PITA to swap caps but you'll get another 5 years out of itComment
I require a circuit diagram for delta power supply from a Philips 32PFL5522D\05 T.V. Any help would be appreciated. Many thanks.Comment
https://www.facebook.com/Telford-Tel...7894576335359/Comment
by Agx03I Need help finding this resisteor for a Rog Ally Z1 extreme. I cannot find one anywhere. RES 20m OHM 1W (0612) 1%//CYNTEC/RLM1632W-6F-R020-FNH-50 PRS890108-14-2025, 05:00 PM
by diggittHi,
I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you-
by jimbofzi have replaced many leds strips that have changed blue when they are worn
and the new replacements are perfect white
but when fault finding do quantum leds always look blue? -
by elgollo51Good afternoon, please, someone who has an HP 850 G5 mainboard can help me get the value of the resistor that I indicate in the image, please, In the boardview it appears without data, but in the schematic neither the value nor the correct position appears, The card is a COMPUTRO 6050A3079801-MB-A01 (01) and is identical to the boardview 6050A2945601-MB A01, the resistance is indicated with yellow arrows in a red box. please help...
10-11-2025, 04:15 PM -
by ditchmagnetI found the schematic for my board and the capacitors I need on it. They are the same part "0.1u16x SHAPE C0402" capacitor. Trying to find replacements online, not sure what to search. Searching 0.1u16x doesn't show any results of a part I can buy.
Edit-
Ok, I think I found the part. GRM155R71C104KA88D should work. I just ordered a reel. hopefully I can get them soldered in correctly....10-11-2025, 01:29 PM - Loading...
