Modding Cool Master RS-400-PSAR-13
  • flyboy_ont
    • Jan 2015
    • 9
    Hi All
    I would like to modify a Cool Master RS-400-PSR-13 400W PSU for 13.5v to 13.8v.
    The PWM chip is a 2012. I've read that this can be done by changing resistors in the feedback circuit to the 2012. I have no idea how the 2012 works so no idea what resistors to change.
    Any help would be greatly appreciated.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8206
    Re: Modding Cool Master RS-400-PSAR-13
    If you don't mind... why would you want to change it? To run ham gear? Most power supplies have a variable resistors near the PWM. One should change the output voltage on the 12V rail. Be careful and watch that the output voltage is not exceeding the voltage rating on the caps.
    • flyboy_ont
      • Jan 2015
      • 9
      Yes I would like to change it for ham gear. There is no variable resistor on the board to adjust.
      I've been trying to trace back the 12V and 5V circuitry to see if I can figure a way to raise the voltage.
      I already have 35v caps to replace the existing ones.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8206
        I just hope you aren't using it for your HF, as these power supplies aren't filtered that great. I have modded some ATX power supplies before, but I used those that had a trimmer in the circuit. Once you find the right resistors, you can take them out, wire an external trimmer on it and adjust the voltage also for bench use. There should be 2 resistors close to the PWM chip. Whats the part number of the PWM? Maybe you can get the pin out off it and figure out the resistors they use that controls the PW on the chip.
        • flyboy_ont
          • Jan 2015
          • 9
          Yes I want to use it for HF. Can I add filtering?
          The PWM chip is 2012 and I have the pinout for the chip.
          I have two other PSU's but they use an ICE chip (dont know the exact number off hand). Neither of them have a var. resisitor.
          • flyboy_ont
            • Jan 2015
            • 9
            https://www.badcaps.net/forum/showth...light=2005+pwm
            This is the thread for the 2012 pinout.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8206
              Pin 13 COMP is the duty cycle control.
              • flyboy_ont
                • Jan 2015
                • 9
                Is this the pin I look at for changing the reisitors for a var. one?
                  • 31077
                  does it have any opto-isolators?
                  • flyboy_ont
                    • Jan 2015
                    • 9
                    No opto-couplers.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8206
                      Can we see some good pictures?
                      • flyboy_ont
                        • Jan 2015
                        • 9
                        I will have to take some.
                        In trying to figure if there was a feedback trace back to the 2012 chip, I started to disassemble the 12v and 5v section. On both the 12v and 5v section I pulled a cap, choke and another cap. After that it went directly to the secondary toroid windings.
                        Capleaker and stj thanks for helping so far.
                        • flyboy_ont
                          • Jan 2015
                          • 9
                          At the junction of the 5V winding and filter cap, a trace goes back to pin 4 on the 2012 chip, which is the 5V monitor line (I assume).
                          Could I put a voltage divider of resistors here to fool the chip it was getting less than 5V?
                          • TinkerTron
                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                            by TinkerTron
                            Hey everyone,
                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                            Instead, here's what's been bugging me so far:
                            The schematic...
                            03-06-2025, 02:03 PM
                          • brightest_z
                            Hot Air Blew Away Resistors Near Bios
                            by brightest_z
                            Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                            Does anyone with more knowledge, and experience than I, know if this is the case?
                            12-11-2024, 08:34 PM
                          • jinu_j
                            LED driver circuit. Burnt Resistors
                            by jinu_j
                            Hi Folks
                            This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
                            Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
                            But i have some queries on this circuit
                            1. The resistors that burnt to crisp...
                            08-26-2020, 01:24 AM
                          • karatzdi
                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                            by karatzdi
                            I know some might say... just buy another one. Sell it as parts..!
                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                            Spent some time downloading the Service...
                            06-11-2024, 08:38 AM
                          • smic717394
                            Mac Air A1466 2012 cpu 300%
                            by smic717394
                            I bought a mac air 2012 very cheap, because the customer didn't want to fix. After reflowing the ram chips the laptop works fine, I tested the ram and no error. But The fan goes at max speed after few seconds. Running the Apple diagnostic finds an error 4SNS/1/C0000008: Th1H--124. and the cpu usage is like 300%, After disconnecting the webcam cable that on the 2012 model is on the IO board, the laptop, the laptop runs fine, and running the apple diagnostic finds no errors. So the problem is related with the webcam, but I suspect the problem is no the webcam but the light sensor....
                            02-06-2024, 03:26 AM
