PowerMac G5 psu not turning on
  • neclovek
    • Dec 2014
    • 12
    • Slovakia
    Hello, recently one friend borowed me a G5 psu which doesnt work.
    Its a 1000W API4FS13. When i plug it in, 5Vsb and 25Vsb are present. When i connect PS-ON to ground, the relay clicks two times and nothing happens, no voltage on 3,3V, 5V, 12V pins.
    Another thing is - I cant find PWM ic on the board. I looked at it for half an hour and couldnt find the damn little thing. Maybe i am just blind.
    Anyway, i hope someone will help me fix that thnig.
    • 30934
    Re: PowerMac G5 psu not turning on
    maybe the chip is under the board or hidden under a large component - got a few foto's ?
    • neclovek
      • Dec 2014
      • 12
      • Slovakia
      Ill post some photos later - now i have too much of unexpected work...
      • neclovek
        • Dec 2014
        • 12
        • Slovakia
        HERE is all the pornography, i mean photography...looks like pornography to me If you need more photos or photos of specific parts, i can do more.
        • cheapie
          null
          • Jul 2010
          • 849
          The bigger chip in the 6th picture is a Fairchild ML4800CP PFC/PWM combo controller.
          • neclovek
            • Dec 2014
            • 12
            • Slovakia
            Oh, okay, now it makes sense, thanks. I was just expecting something like KA7500 or something like that. Well, I gues that I was expecting wrong
            Now "only" thing left is to fix the damn thing...
            • neclovek
              • Dec 2014
              • 12
              • Slovakia
              Nobody?
                • 30934
                we where waiting for you.
                looking at the datasheet, find the startup capacitor on pin5 and replace it.
                dont question how it looks - just replace it.
                • neclovek
                  • Dec 2014
                  • 12
                  • Slovakia
                  But i need to know it. I dont have proper tools to unsolder whole controller board so i cant just look. Is it electroyitic? Or smd?
                    • 30934
                    it'selectrolytic, but i dont nowif it's smd.
                    if it is then it will be even more likely to be dried up.
                    • gustaznkr
                      Nitro 5 AN517-54-51RQ (LA-L181P) Dead after messing around with bootable bios mod!
                      by gustaznkr
                      Hey guys! I've recently found out this amazing forum where people talk and discuss about electronics repairs and i'm actually amazed with everything that here's have to offer.
                      Oh well, i came here looking for a simple bios file in order to get my main laptop working again, but after a while trying to figure out what the hell was going on, i'm quite concerned that it would be worse than i tought. I was fooling around with Mr. Smokeless's UMAF BIOS mod, looking for a way to enable CSM compatibility and legacy boot on my device.
                      Device specs:
                      AN517-54-51RQ (LA-L181P)...
                      06-09-2024, 08:49 AM
                    • Sparklingx
                      HP 450 g1 keeps turning on even tho shutdown/sleep
                      by Sparklingx
                      HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                      09-23-2024, 12:34 AM
                    • khelane
                      Satellite PRO A50-A Not turning on after turning off Windows
                      by khelane
                      Hello
                      A device with specifications
                      Toshiba Satellite PRO A50-A is here to replace the hard drive.
                      The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                      The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                      04-20-2023, 06:28 AM
                    • Rabit
                      VX3276-2K-mhd-2 Random Turning off
                      by Rabit
                      Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                      When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                      This can be signs of bad capacitors causing overheating PSU ?
                      06-17-2024, 09:30 AM
                    • shakib200
                      Dell latitude E7240 not turning on if adapter plugged in
                      by shakib200
                      Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
                      03-31-2024, 12:55 PM
