If it is made for DC there will be no 4 rectifers diodes on that board.
Post 29 shows the bottom side as I requested but I did not trace out the connection yet, I can see that the filaments are connected in series.
Easy enough verify if the caps are connected to the Bridge out put + and -, also easy to check if the caps are in series or in parallel.
Just checked the bottom tracks and also powered it up with 24 AC , i get 16 volts on each capacitor that are in series, also the IC is getting around 15 volts .
But why they have used 50 v caps if its only for 16 volts ? maybe its not 24 volts.
So if you check the resistance + of one cap is connected to the - of the other cap?
- to - of each cap shows <1 Ohm?
So far it looks like bridge drive are the two MOSFET in series and another half bride are the two caps.
If you look at the app notes AN108. You will see the two caps are in series and they are connected to the + AND - of the power supply so the Voltage at the center point will be half of the power supply voltage.
Cap voltage rating will usually be twice the running voltage for safety margin, same for rectifier diode rating, you will want it to be at least twice the Voltage or more.
The voltage on the cap will not at 16V when the circuit is running.
the cap voltage in that design may be irelevant (providing they arent too low),
the caps may have been chosen to handle the current, they probably have pretty high ripple rating.
