Replacing batteries with power supply
  • clearchris
    • Dec 2013
    • 687
    Hi.
    I am looking at replacing 4 C cells with a wall wart, because I'm tired of going to the store for C batteries. There's a wrinkle here, the unit pulls ground and voltage off 4 batteries in series, and also two in series. So, 4 batteries, three wires.
    (GND)--[- +]---[- +]-(3v tap here)-[- +]---[- +]-- (VCC 6v)
    I figure I can replace it with a 6v wall wart and a dc-dc buck step down converter for the 3v circuit.
    Is there anything I should be concerned with here? I think it might be a good idea to put a 12v MOV in there to protect against spikes, I imagine that batteries don't have that particular problem, so there would be no protections against it on the board.
    It drives a board, an actuator and an LED display. I assume the LED is running at 3v, the rest at 6v.
    Thanks!
  • Agent24
    I see dead caps
    • Oct 2007
    • 5096
    • New Zealand
    Re: Replacing batteries with power supply
    You might want to use a linear regulator for the 3v rail, a DC-DC converter may be too noisy, if the unit expects batteries.
    For the same reason, you might want a linear transformer for your wall-wart too.
    Or maybe I'm just being paranoid... lol
    -David VanHorn
      • 31304
      you need to work out how much current you need on each voltage first.
      and how exactly is this 3v used?
      keeping in mind the 3v supply may be referenced to the + rather than the ground.
      it could even be running +/-3v centertapped.
      can you foto or draw the circuit?
        03-31-2024, 02:12 PM
      • m1ch43lzm
        Replacing 2xAA / 2xAAA alkaline batteries with Li-Ion / LiPo battery?
        by m1ch43lzm
        Hi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
        I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
        I'm open to suggestions on whether i should use an LDO or another type of voltage...
        05-27-2025, 05:34 PM
      • carrzkiss
        Cyberpower cps1500avr not charging batteries
        by carrzkiss
        Hello, all.
        Cyberpower Battery Backup Unit.
        I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
        When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
        In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
        Checking the voltage, it was down to 22v.
        I quickly removed everything...
        06-15-2024, 02:10 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        07-01-2024, 06:34 AM
