Newbie - Imac 24 - Liteon PSU - no power at all
  • Mrmullad
    oldman
    • Feb 2015
    • 9
    #41
    Re: Newbie - Imac 24 - Liteon PSU - no power at all
    For some reason it only attached one photo
    Old man but still learning
    • Mrmullad
      oldman
      • Feb 2015
      • 9
      #42
      Again only one photo And yes the model no correct the one photo at a time may be because I am using an iPad
      Thanks once again Dell
      • Toasty
        • Jul 2007
        • 4171
        #43
        NM, saw you did in multi-post. You can attach all to same post.
        Click -> Go Advanced -> Manage Attachments -> Browse (for each file) then click -> Upload (wait for it to finish) then close the pop-up window.
        I can't see anything obvious. FYI - The top isn't made to come off the fuse. It's meant to be un-soldered.
        Do the sniff test and see if you can localize the source of the bang. Look for obvious burn/scorch marks or components missing pieces. Such as the face of the transistors mounted on the heat sinks. Look for debris on the board from a blown component.
        T
        veritas odium parit
        • Mrmullad
          oldman
          • Feb 2015
          • 9
          #44
          That was how I uploaded photos but for some reason it would only do one at a time, the only thing I can find is the burning around the fuse .
          No joy from the seller it was a bit misleading anyway because the website said .co.uk making it look like I was buying from UK company not until I purchased did I find out it was from China as I paid with PayPal I have opened a case for a refund but that is not getting my iPad working
          Dell
          • Toasty
            • Jul 2007
            • 4171
            #45
            iPad?? lol
            Anyway, I need some help from anyone with this supply. The attached pic explains what I need.
            T
            veritas odium parit
            • Mrmullad
              oldman
              • Feb 2015
              • 9
              #46
              On my one it has got 5ono 4 05 L Ac 179P on the larger one if that is any help but I can't read the smaller one.
              Dell
              • Toasty
                • Jul 2007
                • 4171
                #47
                Excellent! Thanks! Usually need a jeweler's loupe for the small ones.
                veritas odium parit
                • Mrmullad
                  oldman
                  • Feb 2015
                  • 9
                  #48
                  We'll PayPal found in my favour
                  So now I need to try and repair the old PSU so let me explain what happened my son sent me the imac by delivery van when he packed it up very well it was working ok but when it got here it not even turn on but when we fitted the PSU that went bang it worked for 4hours before it went pop so it was not anything else so why would a PSU fail in transit.
                  • Toasty
                    • Jul 2007
                    • 4171
                    #49
                    Have you tried the original PSU again?
                    If I understand correctly...
                    -The iMac -was- working when your son shipped it.
                    -The iMac did -not- work when you received it. Yes?
                    Had your original post been clear on that, this would have gone in another direction. My first choice would have been to check all the connectors/connections. A PSU failing in transit is not likely.
                    Re-reading the original post-
                    "then a loud bang and the trip went out when I removed it I found the fuse had blown"
                    Does that underlined bit mean it tripped the circuit breaker?
                    T
                    veritas odium parit
                    • Mrmullad
                      oldman
                      • Feb 2015
                      • 9
                      #50
                      Thanks toasty for your reply
                      And yes the house trip went out but that was with the replacement PSU not the original one that would not work when it turned up from my son,and yes I have tried the original one again just to mak sure, and it still not working.I am going to put the meter across it when I get time.
                      But I thought it was odd that something should happen to it in transit
                      • Toasty
                        • Jul 2007
                        • 4171
                        #51
                        If the bang was that loud and took out the circuit breaker, then the destruction -should- be obvious.
                        You did have the PSU mounted correctly with the insulation in place? I'm thinking maybe something touched the chassis from the mains.
                        veritas odium parit
                        • Mrmullad
                          oldman
                          • Feb 2015
                          • 9
                          #52
                          The only burnt bit was the fuse that blew itself to bits.
                          But I have found the problem with the old PSU the two wires that supply the 240vto PSU one had a break in repaired it and imac working fine.
                          Many thanks for your help.Dell
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • ryogadan78
                            iMac A1418 - No LED, no power after overvoltage on Ethernet port
                            by ryogadan78
                            Hi guys, I need your help again.
                            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                            06-10-2025, 03:49 AM
