Hello Everyone,
I have a Dell HP-P2507FW (Hipro made I guess) PSU sitting on my work bench and it belongs to my brother.
He complained that his PC wouldn't turn on and it that would take him many attempts to get his PC to turn on.... So I immediately suspected the PSU.
I opened the PSU up and found two bulging Arcon caps yesterday night. One 3300uf 10V 12.5mm, the other a 4700uf 10V 12.5mm, the 3300uf was leaking and the 4700uf was bulging.
This morning I had an even closer look and theres a 2200uf 10V 10mm, it was very slightly bulging on the top.
I unsoldered the caps and I've made a mess of the solder where the caps are.... I removed the solder around the caps with a solder wick, but now I can't tell where the old solder lines link up to.
How do I know where each solder line links up to?? I can see that the solder lines are on an area of copper and that the positive and negative poles of the caps are seperated by the brown PCB between the copper areas.
For the 10V caps, can I just use 6.3V caps??.... I believe that the 10V caps power the 5V and 3.3V lines. there are two 3300uf 16V Arcon caps powering the 12V line, but haven't bulged yet.... but I'll replace them too just to be sure.... I can get Panasonic FC 12.5mm 3300uf 16V caps locally.
I have Sanyo WG 3300uf 6.3V 10mm caps and I can get Rubycon ZL 4700uf 6.3V 12.5mm from a local store.
For the 2200uf 10V cap, I am not sure if I should use the 10mm 2200uf 10V Hitano EXR series caps I have here.... they are low ESR, but they aren't ultra Low ESR....
Thanks.
Thanks.
