PSU filter cap leaked after a ground issue?
  • CrysisLTU
    • Sep 2014
    • 14
    • Lithuania
    Hello everyone.
    I've got a Smun AS-350-12 (12V 30A) power supply from aliexpress.com. Yes, it's a chinese cheapee, but it seems that it's quality isn't too bad.
    Anyhow, I was using it with my HF radio transceiver. The PSU was causing lots of EMI/RFI on HF frequencies, and as a radio operator - that's super annoying.
    To reduce that, I took some wire, connected it to the ground terminal of the PSU, and connected that wire to a hot water pipe (I live in EU, in an apartment - no third ground prong in the outlet). EMI got reduced! But just a little bit... The power supply wasn't radiating as much EMI/RFI, but the radio connected to the PSU was still suffering from RF noise.
    I got frustrated after some time, and I've read that some dude with a similar PSU had a similar problem, and fixed it like this (quote): "removed the ac ground wire from the ground terminal and tied it to the DC ground on the power supply. Then I took a 250uf low ESR electrolytic, put the + side to the ac ground screw and tied the - to one of the dc ground screws as to make sure that any RF present on the chassis will have a definite low impedance to ground."
    So, I tried the same. I remember that the cap I used wasn't 250uF, it was a little higher, and it wasn't marked as a low ESR. So, I plugged the cap in, plug the mains cable and... magic smoke coming out of the power supply! Yay...
    I open the PSU up, only to find one DC filter cap that has leaked. It's some cheap SiQing 200v 680uF. There's another cap like that, but it didn't leak. AC Fuse is fine, no other burn marks or anything like that.
    I've already got new same spec DC filter caps installed (yes, I've replaced both), but before turning on the PSU I want to know why the cap leaked in the first place, and will the new caps make it work fine again? Could something else have gotten broken because of what I have done? :/
    I'm a quite a noob in grounding and AC, so help is needed! Thanks a lot.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: PSU filter cap leaked after a ground issue?
    "(I live in EU, in an apartment - no third ground prong in the outlet)"
    How can you connect AC ground to anything when you said you have no AC ground? AC neutral is not AC ground.
    • CrysisLTU
      • Sep 2014
      • 14
      • Lithuania
      Well yes, there was no AC ground connected to the power supply, it's just not there. The other guy, that wrote that fix, does have AC ground.
        "To reduce that, I took some wire, connected it to the ground terminal of the PSU, and connected that wire to a hot water pipe "
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          What did you wire the cap to? Oh, I missed the hot water pipe. Not supposed to use a hot water pipe for a ground, only cold and very close to the water service entrance of the building. Either that or a real ground rod.
          • CrysisLTU
            • Sep 2014
            • 14
            • Lithuania
            It's written in the original post
            Quote: "Then I took a 250uf low ESR electrolytic, put the + side to the ac ground screw and tied the - to one of the dc ground screws"
            Again, the cap was not the same spec.
            • CrysisLTU
              • Sep 2014
              • 14
              • Lithuania
              Why can't I use the hot water pipe? I live in the second floor, no access to any other ground points.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                The hot water line is separated by insulators at the water heater from the cold line. It would be better to use the cold line. It has a better chance at being close to earth ground potential.
                • CrysisLTU
                  • Sep 2014
                  • 14
                  • Lithuania
                  Oh, okay. Makes sense.
                  Any idea why the PSU's DC filter cap leaked then?
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    Cheap and ready to go is my guess unless somehow the cap you connected raised the voltage across the DC cap but I can't think of how that would have happened.
                    • CrysisLTU
                      • Sep 2014
                      • 14
                      • Lithuania
                      It seemed the electrolyte came out from the bottom of the cap, together with some smoke. It was very quick. The power supply was bought new and used for a few days.
                      I still would want to know more correctly what happened, and if I'm okay to try to turn the supply on. I don't want the new caps to die, or the PSU to die in some other way now... Waiting for other people's thoughts
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        Can you post pictures?
                        • CrysisLTU
                          • Sep 2014
                          • 14
                          • Lithuania
                          The old caps have been thrown away. I can post pictures of the PCB if you want.
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            Yeah, that's what I meant. I should try to be more clear.
                            If it was me I want to know why too. I'd disconnect the added cap from the DC ground before powering on the PSU and check for voltage between the DC ground and your external ground while it's on.
                            • CrysisLTU
                              • Sep 2014
                              • 14
                              • Lithuania
                              Here are the photos: https://imgur.com/a/8denv
                              Note the newly installed DC filter caps.
                              Oh, and yes, when I will try to turn it on, the cap wont be connected between DC ground and AC ground connection. I think I threw that cap away too
                                " "removed the ac ground wire from the ground terminal and tied it to the DC ground on the power supply. Then I took a 250uf low ESR electrolytic, put the + side to the ac ground screw and tied the - to one of the dc ground screws as to make sure that any RF present on the chassis will have a definite low impedance to ground."
                                I see the input Ground Earth terminal, but do not see the DC Ground terminal.
                                Can you show exactly how the 250uF cap is connected to this power supply terminals?
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  So you tied DC negative to chassis ground, right? If so I'd undo that too. Not having a schematic it's hard to tell what effect that would have.
                                    I cannot find the info on the terminals of that power supply.
                                    http://www.smunchina.com/html_produc...eries-396.html
                                    The spec does not say that the V- is tied to the chassis Ground either.
                                    I have a feeling that that cap was exposed to line Voltage AC so it smoked, he also did not indicate the voltage rating of that 250uF cap.
                                    • SteveNielsen
                                      Retired Tech
                                      • Jun 2012
                                      • 2327
                                      I think it's isolated. I can see from the pics there's one small blue cap that connect chassis grnd to V-, two to the input transformer secondary legs, and another one to - side of the 680uF cap on the end at the mounting screw hole. I don't see any other connections to chassis.
                                      I suspect the blown cap got AC line voltage too.
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        Concerning the RF noise problem, the standard methods of minimizing that on the DC supply lines to the radio would be using low-pass choke coils inline or pass them wrapped through torroids on the radio end of the supply lines, keeping the DC lines as short possible, and using a 2 conductor with sheild cable if the lines have to be longer than a few inches.
                                        • Califauna
                                          Help with boom box modification
                                          by Califauna
                                          Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                                          I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                                          From factory the specs of the boom box are:
                                          -Power Input: DC 5V
                                          -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                                          -Drivers:
                                          -2 x Woofer, 70mm, 10Ω, 70mm,15W
                                          -2 X Tweeter, 8Ω, 30mm,10W x 2
                                          -Frequency...
                                          12-04-2021, 01:53 PM
                                        • ugamazing
                                          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                          by ugamazing
                                          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                          12-17-2024, 07:05 PM
                                        • Askic
                                          Erratic touchpad behavior - ground issue
                                          by Askic
                                          Hello guys,
                                          I'm having almost exact same problem like described here.
                                          There is also a youtube video about this issue, but remedy suggested in the video doesn't help in my case.
                                          When charger is connected, the touchpad starts with its erratic behavior. So it must be the ground issue. I'm not sure I understand exactly how to solve this.
                                          Can you please have a look at the attached picture of the touchpad and suggest what to do exactly to try this solution?
                                          In my case it is Acer M3 laptop and not Asus, but the symptoms are the same. Without...
                                          08-19-2021, 03:44 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
