PSU Primary cap question
  • Almighty1
    • Apr 2014
    • 222
    I have a question concerning PSU Primary caps as I was looking at reviews of different PSUs and the Corsair AX1200i for example runs on a pair of 450v 470uF caps, am I correct this can handle 900v combined?
    http://www.hardocp.com/article/2012/...3#.VByPkFXMTyc
    On my PC Power & Cooling Turbo-Cool 450ATX, it uses a pair of 200V 1000uF caps but it auto switches between 115VAC and 230VAC so would this mean the pair of caps can handle 400V combined since if it was just each cap, then 230VAC would have blown the 200V rated caps.
    Then the next question is what is the purpose of putting in a pair of 450V caps since wouldn't just one be able to handle 230VAC without issues?
    Re: PSU Primary cap question
    Well, it depends how the caps are connected, in parallel or in series, you need to find that out. The highest DC Voltage feeding the SMPS circuits in the primary side will be about 400VDC.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      They are connected in parallel to equal more capacitance for input filtering. When you have such a high wattage PSU like that one, you need quite a bit of bulk capacitance. Together they equal 940uF. It would be much more difficult to fit a 1000uF 450V cap in there, so that's why they decided to use two 470uF instead.
      The two 1000uF 200V caps are connected in series. In this configuration, the voltage is doubled and the capacitance is cut in half. They're essentially the same as a single 500uF 400V capacitor.
      • Almighty1
        • Apr 2014
        • 222
        Interesting, I never knew the DC voltage can exceed the incoming 230V AC voltage. Thanks both budm and Pentium4 for the insight, always good to learn how things work!
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          This is why the older designed PSU's come with a voltage selector switch. All the switch does is switch the primary capacitors from being in parallel (115V) and series (230V) That's why 200V caps can be used on 230V
          I believe the voltage is stepped up so that the switchers can pulse the current to the main transformer, which likes to run around ~375V
          • retiredcaps
            • Apr 2010
            • 9271
            The AC voltage gets rectified into DC voltage.
            In North America, we have 120V AC. This gets rectified into about 170V DC.
            That is, 120V AC x 1.414 = 169.68V DC.
            If you have PFC involved, that DC voltage can reach nearly 400V DC.
            For 230V AC, we get 230 x 1.414 = 325V DC.
            This is why the big filter capacitors are rated at 400V or more.
            --- begin sig file ---
            --- end sig file ---
            • retiredcaps
              • Apr 2010
              • 9271
              Wiki explanation ...
              http://en.wikipedia.org/wiki/Switche...ectifier_stage
              • Almighty1
                • Apr 2014
                • 222
                If I am reading the wiki correctly, 115VAC will have a 163VDC max while 230VAC is basically twice that. As for switching power supplies, I do remember the very old power supplies from 2000 and earlier had them but I thought those were only in the cheaper power supplies because it was probably cheaper to put in the selector switch than to put in something that did autoselection of the input voltage. Although on the Oppo BDP-105/BDP-105D Blu-Ray Disc Players which are recent models, they still do the selector switch on the back.
                Now I have another question, I haven't seen this discussed on the forums but would changing the any of the capacitors to either a higher voltage or higher capacitance actually increase the AC input Amperage current or does that depend on things other than the capacitors since I sure don't want my 115VAC 10A input to turn into 15A.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Changing the values of the caps would have no affect on this. However higher voltage caps can do better over time since they can handle the inrush spike better than lower voltage, but input capacitor failures are extremely rare under normal operating conditions, even the worst brands do okay here.
                  Yeah, PSU's are very fascinating
                    If it has active PFC Votage booster, then the voltage will be in 360~400VDC range.
                      "Now I have another question, I haven't seen this discussed on the forums but would changing the any of the capacitors to either a higher voltage or higher capacitance actually increase the AC input Amperage current or does that depend on things other than the capacitors since I sure don't want my 115VAC 10A input to turn into 15A." Higher capaictance will increase the inrush current when the power is applied to the unit, once it is running, the load will determine how much current it will draw on the AC input side.
                      • wa2ise
                        • Mar 2008
                        • 9
                        If I am reading the wiki correctly, 115VAC will have a 163VDC max while 230VAC is basically twice that. As for switching power supplies, I do remember the very old power supplies from 2000 and earlier had them but I thought those were only in the cheaper power supplies because it was probably cheaper to put in the selector switch than to put in something that did autoselection of the input voltage. ...
                        ...would changing the any of the capacitors to either a higher voltage or higher capacitance actually increase the AC input Amperage current or does that depend on things other than the capacitors since I sure don't want my 115VAC 10A input to turn into 15A.
                        The supplies that are rated to accept 100V to 250V AC don't really do an "autoselect" like the switches on PC power supplies had. These supplies will just adjust their switching duty cycles to convert whatever the rectified input voltage to the desired output voltages (via the transformer).
                        Replacing the caps won't change the power supplies' average current demand off the powerline.
                        • Almighty1
                          • Apr 2014
                          • 222
                          Good to know that changing the value of caps would have no effect on the input current.
                          I'm looking for a replacement for the 2x200v 1000uF Teapo 85C capacitor pair 25mm and it seems that the Panasonic TS-ED at 200v has higher ripple current and lower ESR than even something higher than 200v's so probably staying with 200v seems to be a safe bet. I noticed that some people on other Power Supplies seems to ask to replace caps with a higher capacitance rating such as 3300uF replacements for the 2000uF caps but I was advised with the PC Power & Cooling Turbo-Cool 450ATX, the same capacitance is fine as PCP&C Turbo-Cool's are over-built when they were designed. My only issue is the PSU is 14 years old being used 24x7x365 and there is this Sanyo OS-CON 2.2uF 25v polymer capacitor which seems to have no replacement available as it seems like my options are Sanyo OS-CON 2.2uF 25v in a 10 pack on Ebay from someone in China which is highly likely to be fake or getting one of the Panasonic branded OS-CON's 6.8uF 25v polymer capacitors as Panasonic bought Sanyo and rebranded Sanyo OS-CON under their name, would there be anything bad about going with the 6.8uF as it's 3.4x the original capacitance since I'm trying to replace all the caps at one shot unless the Sanyo still has a long life, I measured capacitance of the Sanyo using a Multi-meter and it still reads 2.2uF.
                          Speaking about capacitance in Power Supplies, what would be considered a acceptable ESR range as I noticed that people would say the ESR is too low for a PSU but suitable for a motherboard, exactly where is the line for ESR distinguished if it's suitable for a PSU or not when looking at specs?
                          What does PFC do exactly since I know my PC Power & Cooling Turbo-Cool 450ATX does not have PFC as I remember PFC was added in newer models and it's usually mentioned in the product model number. Is PFC only for 115VAC or also for 230VAC since it would seem 230VAC with PFC if it exists would be higher than 400VDC.
                          • Almighty1
                            • Apr 2014
                            • 222
                            Forgot to ask but what is the proper way to discharge the primary capacitors in a power supply?
                              Through a resistor which the value and the Wattage will depend on the Voltage on the cap and the capacitance, the time constant (R*C) will determine what the Voltage will be after first TC which the Voltage will go down by about 63%.
                              • Almighty1
                                • Apr 2014
                                • 222
                                Hmmm, is there another way to do it? Like if it's unplugged from the AC, will it just discharge on it's own and how long will it take?
                                  Yes, you can, all you have to do is just check the Voltage on the cap to see if it goes down below 50VDC. The discharging rate will depend on the load connected to the caps.
                                  • bauto601
                                    KDM 480W PSU upgrade succes! (opinions?)
                                    by bauto601
                                    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                    A "nice" YoungYear unit? - Badcaps
                                    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                    12-26-2023, 03:05 PM
                                    KDMPower MIPC MI-X8775CD [PCB WF-C rev:E]
                                    by momaka
                                    Remember that cheap $15 PSU that dmill89 posted a while back here?
                                    https://www.badcaps.net/forum/showthread.php?t=72229
                                    So I was randomly browsing on eBay (as always) and saw a listing for supposedly the same “775 Watt” PSU with starting bid at $1. Description stated “for part or repair”, with the owner/seller mentioning the PSU had blown/shorted. Surely I could spend a few $$ more and get the same PSU as dmill89 right from Amazon brand new and (probably) working… but where is the fun in that?!
                                    So I got this one instead...
                                    11-17-2020, 12:03 AM
                                  • temyth
                                    Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
                                    by temyth
                                    Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
                                    The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
                                    01-07-2024, 04:50 PM
                                    KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                    by momaka
                                    For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                    http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                    I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                    What mostly drew me into buying it is its 2x PCI-E power connectors...
                                    03-29-2022, 11:34 PM
                                  • DanielCoffey
                                    Bosch GRA53 36V Lawnmower - no motor
                                    by DanielCoffey
                                    Hi folks. I have a Bosch GRA53 36V lawnmower that has developed a fault and will not spin the blade.
                                    I should say for the purposes of guiding what how you can explain things to me that that I have only modest knowledge of electronics, own a basic multimeter and soldering iron.
                                    The mower is four years old, out of warranty, discontinued and the brand has been sold to Honda who have iterated on the design a couple of times and now sell their own 36V mower. My mower was effectively a prototype when Bosch tried the 36V Bosch Professional range of garden equipment which...
                                    08-06-2023, 12:40 PM
