Help Needed for PSU Board Identification
  • lisahamp871
    • Sep 2024
    • 7
    • Italy
    My almost 15 years old desktop PC decided it was about time not to power on anymore. I replaced the PSU with a spare one I had and it went back on so I guess it was it. Now I'd like to try to take a look at the old one that went bust but I'm having trouble in identifieing it. I've taken some pictures of the board but haven't been able to find the schematics or almost anything online, expect for the LC500H-12 itself, the inside board seems to not showup anything.
    Any assistance in identifying the board or pointing me toward the right schematics would be greatly appreciated!
    Thank you in advance for your help!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Probably hard to find the right schematic for it. However you may look at the ICs get the data sheets.
    For example: what PWM and how does the protection work?
    Did you try to warm it up a little and then force start it? Observe exactly what the power supply does or doesn’t do, specifically when you start it. Does it try to start at all, or starts for a split second and then shuts down etc. You need to figure out on which side of the power supply the problem is. Is the problem on the primary or on the secondary side?
    I suggest you start noting down all the important ICs. Could be anything at this point. How did the PSU die?
    • R_J
      • Jun 2012
      • 9634
      I found the same post on another site, do what they said, check if you have standby voltage
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
