Capacitors commonly used in PSU's?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi people, want some help
    What capacitors are commonly used in power supplies?
    Big Pope has a Samxon RS 7000H cap in stock. 3300uF 16v 12.5x35mm impendace: 0.015Ω ripple: 3400
    I think it looks really good however 12.5mm is a tight fit in many cases. Most PSU's use 2200uF 16v 10mm caps right?
    So we need those too
    And then in 6.3v rating we need 1000uF, 1500uF 2200uF and 3300uF
    Anything I am missing?
    Big Pope can also get a new series of caps, Samxon GT. They have a life rating up to 10000 hours, I'm attaching the PDF of both caps, please provide some input on which caps you would like Big Pope to have in stock
    (I'm uploading them here because Samxon's site is slower than a snail that lost all the gooey stuff on the underside that makes it go forward )
    Last edited by Per Hansson; 05-11-2014, 04:55 AM. Reason: Offsite files uploaded due to problems with host
  • bgavin
    • Jan 2007
    • 1355
    Re: Capacitors commonly used in PSU's?
    I have a spread sheet working for PSU and motherboard caps. I keep adding to it as I gain more information.
    http://www.bgavinsound.com/reference/
    • Logistics
      • Apr 2007
      • 721
      All the big caps in my Antec SL350 were 10mm. Although, there was a 4700uF 10V in there and rather than use a 12.5mm as it was silk'd for, they used a 10x36mm... from Fuhjyyu!
      Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yea, I've seen those 4700uF 10v 10mm caps too, probably not near that uF rating even when they are new I would guess
        • Jmine
          Commonly used SMD capacitors
          by Jmine
          I'm hoping to order some SMD capacitors for the first time and I was wondering which size and value are mostly used in laptops. I'm looking to buy an assortment of capacitors. Any thoughts?
          03-16-2023, 07:22 AM
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • Ady2017
          Are there any datasheets available for Elna RJG capacitors?
          by Ady2017
          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
          05-25-2025, 02:19 PM
