Capacitors commonly used in PSU's?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi people, want some help
    What capacitors are commonly used in power supplies?
    Big Pope has a Samxon RS 7000H cap in stock. 3300uF 16v 12.5x35mm impendace: 0.015Ω ripple: 3400
    I think it looks really good however 12.5mm is a tight fit in many cases. Most PSU's use 2200uF 16v 10mm caps right?
    So we need those too
    And then in 6.3v rating we need 1000uF, 1500uF 2200uF and 3300uF
    Anything I am missing?
    Big Pope can also get a new series of caps, Samxon GT. They have a life rating up to 10000 hours, I'm attaching the PDF of both caps, please provide some input on which caps you would like Big Pope to have in stock
    (I'm uploading them here because Samxon's site is slower than a snail that lost all the gooey stuff on the underside that makes it go forward )
    Last edited by Per Hansson; 05-11-2014, 04:55 AM. Reason: Offsite files uploaded due to problems with host
  • bgavin
    • Jan 2007
    • 1355
    Re: Capacitors commonly used in PSU's?
    I have a spread sheet working for PSU and motherboard caps. I keep adding to it as I gain more information.
    http://www.bgavinsound.com/reference/
    • Logistics
      • Apr 2007
      • 721
      All the big caps in my Antec SL350 were 10mm. Although, there was a 4700uF 10V in there and rather than use a 12.5mm as it was silk'd for, they used a 10x36mm... from Fuhjyyu!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yea, I've seen those 4700uF 10v 10mm caps too, probably not near that uF rating even when they are new I would guess
        • Jmine
          Commonly used SMD capacitors
          by Jmine
          I'm hoping to order some SMD capacitors for the first time and I was wondering which size and value are mostly used in laptops. I'm looking to buy an assortment of capacitors. Any thoughts?
          03-16-2023, 07:22 AM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
          After all of...
          07-13-2024, 08:14 PM
        • Cama
          Solar Inverter - SMH-II - 2 missing capacitors
          by Cama
          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
          My model is : EASUN SMH-II 7 KW
          Mother Board : P/N 18947-002401250250
          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
          Thank you...
          09-12-2025, 02:50 AM
