Samsug washing machine. Power supply DC41-00189a board issue
This topic has been answered.
  • Soulzink
    • Apr 2025
    • 12
    • France
    I am trying to fix a samsung washinmachine power supply main board.
    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
    The power supply board reference is the following: DC41-00189a
    I have followed one thread (https://www.badcaps.net/forum/troubl...roblem?t=67604) and have done the following check:
    - Big relay (GT 1A 12D) click when 12v dc is provided and shows 0.00 ohm resistance
    - Main fuses are good
    - Main 2 big capacitor seems good (tested whithout desoldering but got good capacitance value)
    - Tested some diode too and didn't find one wrong yet
    Context:
    My washing machine used to run fine and some times when i started a washing cycle it would run and turn Off rondomly.
    I just had to switch it On again and push the resume button and it would resume the cleaning cycle where it left it.
    Given time, it started do it more frequently until a day where this was off and i couldn't turn it on.
    Hence I would give a little kick next to the power supply main board. It sometimes helped but only 2,3 times.
    Now I have not used the board for a long time (>1 year) and wanted to try troubleshoot it to learn more.
    When i tried it again on the washing machine it worked and was able to launch a washing cycle but shortly after it turned off.
    There is one special aspect with this faulty board. When it is connected to the machine and is connected to electrical socket we will here a continuous click from one of the big relay.: it will make contact (close) then open, again and again.
    When it was randomly working, it used to make it too but when it was working this cycle clicks didn't occur. In fact when connected to power socket it should click once and stay closed.
    Also, I found out that there is not constant DC voltage among the board: it is flickering (1v , 2v, 5v then 0v, 1v, 2v, 5v). It is synchronised with the cycling clicks.
    I noticed a smps transformer but not sure how to test it.
    Hence, if you have any help or suggestion, please let me know.
    Thank you in advance
  • Answer selected by Soulzink at 08-21-2025, 04:40 PM.
    Soulzink
    • Apr 2025
    • 12
    • France
    Hello all,
    I come back after long time to provide feedbacks on this topics and the encountered issues for everyone.
    After checking the voltage i didn't found the root cause of the issue. So I ended up changing all optocoupler as it was cheap. I found one faulty in diode mode. After replacing it the board was not clicking anymore and the washer was turning ON (in attachment the faulty one).
    I am sure to have check them all before but I guess this is the tricky part with "randomly" working.
    Hence, the flickering voltage and the issue was gone but after that and surprisingly the motor kept blocking.
    In fact it was trying to move but kept stopping as if it was blocked. After checking that the drum was not physically blocked I ended up replacing some component.
    At last I ended up replacing the big chip beneath the heatsink that was replaced previously and was almost new (IKCM15F60GA) and all issues related to the motor were fixed.
    So It is working now for 2 months and it seems that it is fixed for good.
    It doesnt matter my next washing maschine will be a Miele xD
    Hope this could help some one.
    • klynstronic
      • Jun 2022
      • 45
      • espaƱa
      Hi. I would first clean the circuit board and check for any potentially sulfated traces, as well as cold solder joints and component contacts...optocouplers, etc. Best regards.
      • Soulzink
        • Apr 2025
        • 12
        • France
        Hi klynstronic,
        Thank you for your help.
        I didn't notice any bad component or sulfated/overheated traces. Therefore to my eyes there is nothing looking wrong.
        I already tried to reflow some solder joint but not all (i vould say maybe 20% off all solder joint).
        I did it where I think there was big load of current and heat. To be more precise around big relays and capacitors and the chip behind the huge heat sink.
        But there was no improvment.
        Can someone explain the main principle of power supply main boards ?
        I understand there is 230v ac incomming from power socket but then ?
        Is it converted into dc directly within the smps transformer ?
        what about the bridge rectifier ?
        I want to try troubleshoot from the start to see what component is not providing its expected voltage.
        Here is a list of the main component i noticed:
        - 2 big relays (Gt 1a 12d - 25a 250v ac - 12v dc coil)
        - 1 big bridge rectifier
        - 3 smaller relays ( 12v dc coil)
        - one smps transformer with 5x2 pins
        - one pwm controller next to the smps transformer
        - 2 voltage regulator (one 5v output and the other is 15v output)
        - one big component (icmp ??) That is beneath the huge heat sink
        - 2 big capacitors 820uF 250v
        - other small capacitors
        - bunch of fuse, diode and resistance
        I consider myself a newbi but want to learn.
        In addition to the test made on relays, capacitors, diode and fuse, I have replaced the pwm controller but nothing changed.
        My guess is that nothing will work if no constant dc voltage is provided... so trying to check where the ac is converted to dc and how.
        Hope this can provide additionnal information.
        • klynstronic
          • Jun 2022
          • 45
          • espaƱa
          Hello. I don't think you're a beginner. Do you have a microscope to observe the circuit? In fact, you can see many things invisible to the naked eye. As you know, transformers step up or down the voltage, which is then rectified by diodes to convert AC voltage into DC voltage, which is filtered and stabilized by capacitors, resistors, etc. You can also observe the pulses with an oscilloscope. Best regards.
          • CapLeaker
            Leaking Member
            • 8328
            What Samsung model washer is this?
            Here is another thread for you to read: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-power-supplies-and-power-supply-design/81352-samsung-washing-machine-won-t-power-on-dc41-00189a
            https://www.linkzuhause.com/samsung-washer-stopped-spinning-wf80f5ebp4w-dc41-00189a/
            As for the clicking relay. Is it the main AC relay that clicks in the corner? There are 3 things to check. One you already did and that is the relay. Then there is a DC enable circuit and there is a 12 or 15V regulator and with that there are some capacitors to check too.
            While your at it, take that big heatsink off like in the vid on the second link and put new paste. Also desolder and resolder that IC with fresh solder.
            edit:
            Here is a service manual for a washer that uses the same board
            https://www.manualslib.com/manual/25...06-Series.html
            edit #2: look at page 54 on the pdf... It's not the same washer but the idea is basically the same.
            • CapLeaker
              Leaking Member
              • 8328
              Finally found the right schematic for this DC41-00189A
              ​Not easy to find!
              • Soulzink
                • Apr 2025
                • 12
                • France
                Sorry for late reply, I spent my entire sunday fixing my car.
                @klynstronic : Well, I enjoy trying to troubleshoot and fix some eletronics in order to understand/learn and sometimes buy very low faulty product to repair them for myself. So I got some tools including a small numerical microscope but I didn't follow engineer school and therefore I only know of thing I can read and see on the internet
                As for the faulty board, after spending lot of time trying to check traces and other things, I reflowed as suggested all solder joint which took me a long time. But it didn't make any change. Still that clicking relay and voltage flickering from 0v to 5v.
                I tried to check smps transformer pins but didn't get any voltage reading. However it seems the coils within are still good (tested in continuity mode). So either he is not getting AC or something is preventing it to proceed like a ic controller "shuting it down".
                @CapLeaker : Hello, thanks for the help.
                My washing machine is a samsung WF1114XBD.
                Thanks for the two links. In fact I already saw them before. The first one is from someone having kind of the same trouble with no constant voltage. But I didn't have a short or at least nothing seems shorted. Also the second link was talking about bad traces but I didn't find any bad in continuity mode. Maybe I will have a double check on all traces again just to be sure but it won't be easy to be 100% sure since it is random. For instance on saturday night while trying to check voltage, the board stopped clicking and board was working again. It might still be working today (I will check when i get back home) but as always I would launch a washing cycle and it would stop in the middle.
                It looks like either a bad contact, or a "restart signal" cycling for some reason, or a "tired" component (capacitor, resistor, diode). Since I have tested all relays contact and reflowed all solder joint, I think contacts are good but can't be 100% sure.
                Regarding the clicking relay, you are right. It is the one at the bottom left (top view). I found out that some flickering dc voltage is provided to him hence the encountered behaviour when the card is not working and the clicking stopping when it works.
                I find 20v next to the smps transformer when this works and it is provided to first voltage regualtor which output around 17V and is provided to second voltage regulator which output around 7V. But when card is faulty and relay clicking, I find no voltage around smps transformer and flickering dc voltage around those regulators. What do you call DC enable circuit ? PWM IC ?
                As for the capacitors, I didn't desoldered them since everything is glued and it is very difficult to remove them but when I gave it a try on saturday, I found out that multimeter is showing good capacitance for each of them (2 big, and the other smaller ones). But since they are still soldered I can't rely on that 100 %.
                I will probably change thermal paste and clean the board but only if I manage to troubleshoot it because I guess it will be a pain in the a** to remove that glued heat sink xD
                Regarding the manuals, Thanks a lot, I didn't manage to find any on my own. I will have a deep look at it tonight and see if I can go further
                Thanks again for all your replies.
                • CapLeaker
                  Leaking Member
                  • 8328
                  Soulzink
                  I had written my post #5 before I found the correct schematic in my post #6.
                  Reading your last observation of the washer, I suggest heating up the board with wifeys hair dryer, so everything is nice and warm (but not that hot you burn yourself) and then start a washing cycle.
                  My post #6 has the schematic for your power supply and you'll see how that relay #1 works.
                  Edit: Here is a layout of the PSU on where what is.
                  • Soulzink
                    • Apr 2025
                    • 12
                    • France
                    Thanks a lot mate for all shematcis šŸ¤—
                    They are very usefull and reading them I can see that I was almost right on my understanding of this circuit xD
                    Yesterday I tried again to turn On the washing machine and it was still working.
                    I launched a washing cycle and it turned Off ( 20 min from start) and On (after 30 min maybe) then it stayed On for an hour.
                    Surprised I came by checking the maschine and just then motor stopped abruptly and saw a flashing light somewhere around the maschine (not sure where). Everything stopped and breaker popped.
                    I removed the board and checked it: main fuse from AC side was blown.
                    So I think either the tired component finally gave up causing a short or a security mecanism has gave up 🤣
                    I will continue digging this a bit with shematics around the AC part of the board. My guess is that the bridge rectifier has blown.
                    I will try desolder it and check it in diode mode.
                    • CapLeaker
                      Leaking Member
                      • 8328
                      interested to see what you find!
                      • Soulzink
                        • Apr 2025
                        • 12
                        • France
                        Hi there,
                        So I checked the board again before doing anything.
                        I found that there was around 0.5v in diode mode across all pins and any direction from the bridge rectifier.
                        Very weird so I decided to desolder it. I tested it again and it was fine xD.
                        So I kept desoldering things linked to its trace to test them individualy. I ended up desoldering the two big caps and one resistor. However out of the board they were showing good values.
                        Back to the board I noticed that (+) trace and (-) trace from bridge rectifier were showing continuity. Following them I decided to remove huge heat sink and have a look .
                        Here it was ! There were two black spot on 4 pins of the big IC. Following the provided schematics (thanks again ) it is a IKCM15F60GA.
                        I had a lot of difficulties to desolder and remove it. I damaged two trace and there is a small hole into the board now.
                        I think I can manage to fix those later.
                        At this point I am not sure if this faulty component was the cause of all this or if it is only a consequence of another failling thing.
                        I tried to check the component linked to those 4 burnt pins but everything seemed fine (caps, resistor, diode).
                        So...... I ordered another IKCM15F60GA, a new bridge (just in case) and a fuse and will try again when possible xD.
                        I will revert asap
                        By the way, I helped one familly member today to clean its Miele from 2005.
                        I was extremely surprised when I found a pack of shematics of all circuit provided and stored inside it.
                        I was thinking they should be always provided and it seems they did this in the past...
                        • CapLeaker
                          Leaking Member
                          • 8328
                          I figured it now would be that IC under the heat sink. It's a known issue with this board. Keep on going!
                          • Soulzink
                            • Apr 2025
                            • 12
                            • France
                            I have finally received the big IC yesterday.
                            I couldnt wait and soldered it on the board. I repaired the two damaged traces. I have put back the two big 820 uF caps, the resistor and the bridge rectifier (after confirming again good value/behaviour).
                            The machine turned On but it was late (23h30). So I left it and was thinking will try a washing cycle tomorrow.
                            Unfortunatelly when I came back this morning the clicking noise was back on with flickering voltage.
                            I will try dig this further but not now as I have spent too much time on it and need to fix other things (making a diy cat food distributor). I will switch back to it later unless someone has an idea to try.
                            Sorry for the bad news xD
                            • CapLeaker
                              Leaking Member
                              • 8328
                              Look at what PC1, 3 & 5 do on the LED side of the optocoupler. I wonder if the voltage is steady or is on off like the relay clicking.
                              • Soulzink
                                • Apr 2025
                                • 12
                                • France
                                Hi Mate,
                                I remember checking those at the begining. If I remember well there are arround 6,7 of optocouplers at the back side of the board.
                                I tested in diode mode the input side (only passing in one direction) and also checked that there was no short between input and output side. However I didn't check the voltage.
                                I will check them tonight and revert. Thanks for the idea and don't hesitate if you have any other ones
                                • CapLeaker
                                  Leaking Member
                                  • 8328
                                  I wonder what they do if it's clicking or not clicking. But I think is something with the power supply. Check the PWM VCC what happens to it.
                                  • Soulzink
                                    • Apr 2025
                                    • 12
                                    • France
                                    Hi there,
                                    I had a look yesterday but when I connected the board it was working and stable.
                                    I left it connected all night long and it hasnt failed yet... xD
                                    I might launch a washing cycle to make it fail.
                                    I took this opportunity to write down the voltage around these optocouplers in 'stand by' mode and 'On' mode.
                                    I remember that before I replace the PWM IC I found flickering voltage at VCC pin.
                                    I will try make it fail again so that I can check again for the voltage of those.
                                    • CapLeaker
                                      Leaking Member
                                      • 8328
                                      As I understand it there is constant VCC to the pwm while it's working? How many volts do you get?
                                      • Soulzink
                                        • Apr 2025
                                        • 12
                                        • France
                                        Hello all,
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
                                        • penangit
                                          Hp v193 monitor power supply board
                                          by penangit
                                          Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                          I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                          I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                          Steps taken so far:
                                          Checked all...
                                          02-21-2023, 04:00 AM
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
