Optiplex power supply dead
  • Luke Mawdesley
    • 20
    I have 2 Dell Optiplex 790 SFFs that both have dead power supplies. When I plug them in I can hear a spark so they are at least drawing power. I've checked all the power rails and there's nothing whatsoever. The self test button on the back does nothing also. I took it apart, plugged it in and probed the back until the voltage stopped at a mosfet. Is the problem with the mosfet or something else? I de-soldered it and when turned on it stays closed for about 4 seconds before opening again (tested with a multi-meter). The mosfet is this: https://www.indiamart.com/proddetail...047252730.html . Any help is appreciated.
  • CapLeaker
    Leaking Member
    • 8184
    Take wifeys hair dryer and warm the inside up a little then try to power up the PSU.
    • Luke Mawdesley
      • 20
      Any specific part of it?
      • CapLeaker
        Leaking Member
        • 8184
        No. Just blow some warm air inside the PSU for like 30 seconds or so. Then turn on the PSU and see if it runs.
        • Luke Mawdesley
          • 20
          Just tried it and no difference. I should also mention that there are no visible signs of damage on the board and all the caps look fine.
          • CapLeaker
            Leaking Member
            • 8184
            I guess we need straight shot pictures of the board,. Upload them using the attachment function and choose like a small or no thumbnail.
            iI thought maybe the starter cap had dried out and that's why the PSU doesn't turn on when cold.
            • Luke Mawdesley
              • 20
              Here are some pics:
                • 21011
                Here are some pics:
                What model number is on the PCB ,and on the sticker on the metal cover
                • Luke Mawdesley
                  • 20
                  Here
                  • CapLeaker
                    Leaking Member
                    • 8184
                    Do you have 5VSB or is it totally dead?
                    • Luke Mawdesley
                      • 20
                      No, its completely dead with no standby power.
                      • CapLeaker
                        Leaking Member
                        • 8184
                        Is there a little chip starting with TNY xxx? May be an IC or TO220 style mounted to a heatsink with many (5) legs?
                        May be also a TOP xxx
                        • Luke Mawdesley
                          • 20
                          Yes, there's a TNY280PN. Its a small IC with 8 pins I think.
                          • CapLeaker
                            Leaking Member
                            • 8184
                            That thing is doing your 5VSB. Look around and see if power is getting there. Be careful, you are on power mains! If you do get power there but it isn't doing anything, I'd change it out with a new one.
                            The 5VSB is always on. Also check the caps for this circuit. Next there has to be a rectifier diode for the 5VSB on the secondary side. Look that it isn’t shorted!
                            • Luke Mawdesley
                              • 20
                              I'll try this when I can. Where do I ground the multimeter though? Also how do I check the caps with a multimeter?
                              • CapLeaker
                                Leaking Member
                                • 8184
                                Easy. Ground on the primary side is always the negative post of the main filter capacitor. You can’t really test capacitors with an DMM properly. You need an ESR meter for that. Maybe your DMM has a capacitance function, better than nothing.
                                • Luke Mawdesley
                                  • 20
                                  Easy. Ground on the primary side is always the negative post of the main filter capacitor. You can't really test capacitors with an DMM properly. You need an ESR meter for that. Maybe your DMM has a capacitance function, better than nothing.
                                  There was no power anywhere near the chip, however I found the issue somewhere else. I was looking more closely at where the voltage stopped and saw that 2 small capacitors similar to these had blown out and were cracked as well as a resistor that was blown. Should I try replacing these or is there another problem that might make them blow again?
                                  Edit: The resistor is a 4.7 Ohms flame-proof resistor. The capacitors are completely destroyed so I can't tell anything about them.
                                  • CapLeaker
                                    Leaking Member
                                    • 8184
                                    The flameproof resistor acts like a fuse, since it so low in ohm rating. And there is probably where your voltage to the 5VSB stops. The capacitors… they are looking kind of these shown in the picture? Be careful around there we might need to be able to identify them. What colour are they? Anything printed on there or are they burnt to crisp? Pictures? What kind of circuit are they in?
                                    • Luke Mawdesley
                                      • 20
                                      Here are some pics. There is no printing as far as I can see. Also there was power on both sides of the resistors and caps so not sure what that means.
                                      • CapLeaker
                                        Leaking Member
                                        • 8184
                                        Read this thread and also check that MOSFET for short.
                                        https://www.badcaps.net/forum/troubl...-7010-pc-tower
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
