ocz 420 u12 swollen caps
  • predator0357
    • Jul 2014
    • 159
    • Israel
    Re: ocz 420 u12 swollen caps
    Originally posted by c_hegge
    Try this fella - http://stores.ebay.com.au/PC-MotherB...pacitors-Store
    His caps are all NOS, but they should work OK. Topcat here doesn't have much in the way of PSU caps.
    I see two 470uF 16V caps (the Fuhjyyus). They can get replaced by these (http://www.ebay.com.au/itm/6-Rubycon...item43c09e20c5)
    2200uF 10V caps can get replaced by these (http://www.ebay.com.au/itm/8-pcs-Rub...item43c0209c72)
    4700uF 10V caps can be replaced by these (http://www.ebay.com.au/itm/4-NCC-KZE...item43a7c69012). And yes, using 6.3V caps in place of 10V caps is fine on the output
    tnx for the help:-)
    I saw this seller here and saveded it, i picked the 2200 ncc kze and the 4700 u gave me is 6.3v and i need 10v so i found one seller that look ok by the feedbacks he got and the things hes selleing.
    Here the url for this seller
    http://pages.ebay.com/link/?nav=item...755275&alt=web
    Or
    http://www.ebay.com/itm/2-JAPAN-Pana...-/131215755275
    • c_hegge
      • Sep 2009
      • 5219
      Feedback means absolutely nothing when your dealing with caps. 99.9% of people who buy them have no idea how to tell the difference. That seller is not one of the reputed ones, so I wouldn't use it. As I said, there is no problem with replacing 10V caps with 6.3V ones - as they are used on the 5v and 3.3v rails anyway.
      • predator0357
        • Jul 2014
        • 159
        • Israel
        Ok if u said its ok i say aman:-)
        Tnx very much for the help, my after the psu its like a ballon hehehehe
        Its hard here in israel cuz there no anh store that have hi end caps only GP caps and even those if dont buy alot its expencive
        For exmple i bought 7 GP caps cost me 5.2$
        • predator0357
          • Jul 2014
          • 159
          • Israel
          Hi, in this seller he have bouth caps ncc kze, why not buy those?
          • c_hegge
            • Sep 2009
            • 5219
            You could do that. It wouldn't make much difference, though.
            • Behemot
              • 4845
              • CZ
              #26
              If you wanna I have some nice D10 caps, Samxon RS 3300 uF/16V and NCC KYA 3300 uF/6,3 V. Can pretty supply equivalent of everything in there. I also sell some on eBay but you will get it cheaper directly from me…
              • predator0357
                • Jul 2014
                • 159
                • Israel
                #27
                Hi every1,
                I need pls every1 who could tell what cap is cuz this little busterd is glued and i dont want 2 scrapted him now
                Tnx 4 the help:-)
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  You will still need to get the glue off the resistor at the side of it. The glue goes conductive with time and may short it out . Sometimes the glue will soften slightly with repeat coats of IPA.
                  If you put shiney tinfoil down the side at an angle your camera may capture a mirror image of the detail on the side of the cap?
                  • predator0357
                    • Jul 2014
                    • 159
                    • Israel
                    #29
                    Tnx 4 the advice on the glue and amazing idea with tinfoil
                    IPA What is it?
                      • 31040
                      ipa = isopropyl alcahol
                      • predator0357
                        • Jul 2014
                        • 159
                        • Israel
                        #31
                        Hello every body,
                        After close combat with the PSU i got all the values and the main caps that i picked to replace are:
                        NCC KZE 6.3V 4700UF
                        NCC KZE 10V 2200UF
                        Nippon ChemiCon NCC LXJ Series 16V 2200UF
                        Nippon ChemiCon NCC SXE Series 16V 3300UF
                        Nichicon PW 10V 1000UF
                        Nichicon PM 16V 470UF
                        So what do u thinks about the list? The brand\series are ok?
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Those would do fine. Some like the SXEs might be somewhat larger physically than the originals, and be a bit of a tight squeeze to get in (although you could probably get around that by mounting them a few mm off the PCB), but their electrical specifications should be OK.
                          I'd recommend replacing as many of the really small capacitors as you can too.
                          Here are some options for some of the more common sizes (although I'm not sure how many of these apply to your power supply)
                          1uF - http://www.ebay.com.au/itm/15-NCC-LX...item43c00a435f
                          4.7uF - http://www.ebay.com.au/itm/15-Panaso...item460a1a1518
                          10uF - http://www.ebay.com.au/itm/10-NCC-KY...item461e62f143
                          22uF - http://www.ebay.com.au/itm/12-Nichic...item46046b0183
                          47uF - http://www.ebay.com.au/itm/8-Rubycon...item43c09e4709
                          100uF - http://www.ebay.com.au/itm/12-Rubyco...item4613a3b283
                          • predator0357
                            • Jul 2014
                            • 159
                            • Israel
                            #33
                            i have in the PSU:
                            470uf\16v
                            220uf\16v and i have 220uf\25v ky
                            47uf\35v
                            47uf\16v
                            4.7uf\50v
                            1uf\50v
                            0.47uf\50v
                            • c_hegge
                              • Sep 2009
                              • 5219
                              You are covered for most of those with the list I posted. You can use the 47uF 50V caps to replace both the 35V and 16V parts. The 0.47uF is a bit harder. The only 105*C cap available from PCMCS is an audio cap - http://www.ebay.com.au/itm/2-ELNA-Au...item43ca6107a4. It would probably do fine as the original is probably only a general purpose cap anyway. You could probably also use a ceramic cap. I've done that to Antec Smartpower PSUs lots of times when replacing a small 0.1uF electrolytics.
                              • predator0357
                                • Jul 2014
                                • 159
                                • Israel
                                #35
                                Tnx 4 the help
                                But what with the 220uf/16v can i put 25v?
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  I have all of those caps (or equivalents) but 0,47 uF and 220 (no stock ATM). I think even some old used KZE 4700 uF/6,3 V but if you ask me this is way too high current/low ESR for only 420W PSU, this was MB grade capacitor in the times of this PSU.
                                  Samxon RS 3300 uF/16 V in D10x30 offers practically the same as NCC SXE in D12,5x40 mm.
                                  Last but not least, I have way better prices over the c_hegges eBay list. Check.
                                  predator0357: higher voltage is OK if it also fits physically.
                                  • predator0357
                                    • Jul 2014
                                    • 159
                                    • Israel
                                    #37
                                    PCMCS have 0.47\50v panasonic [M] its good enogh?
                                    or just put GP caps from my class?
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      Yep Panny is good brad, I would let it be.
                                      • predator0357
                                        • Jul 2014
                                        • 159
                                        • Israel
                                        #39
                                        what? "Panny is good brad"?
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #40
                                          Panasonic? M is for Matsushita Electric Industrial, former name of Panasonic Corporation.
                                          What's the complete list you need with quantity of each cap type?
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • eryjus
                                            by eryjus
                                            05-10-2023, 11:21 AM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • Foetuss
                                            Gigabyte GA-6OXT :: caps question
                                            by Foetuss
                                            Good evening
                                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                            But I was also suprised about the bigger boys, which are 330µF 25V.
                                            Could it be they used 25V caps because they were cheaper / available at that time?...
                                            02-11-2025, 12:22 PM
