Just Repaired my Central Air Unit and Wouldn't You Know...
  • mmartell
    • Oct 2013
    • 3189
    ...Bad CAP! (could this be part of that whole Taiwan thing ? Lol)
    As an aside the shop here in town I got the part from charged me $44 + tax. Out of curiousity I had searched ebay and the part can be had for about $7. Wtf ? I realize with temps around 90F and a wife and kids to consider I can't wait for shipping but come on ! Do I have "sucker" written on my forehead or are these guys fucking thieves ?
    Re: Just Repaired my Central Air Unit and Wouldn't You Know...
    Shop has to pay for rent and staff, online retailer often doesn't or the costs are much lower with the number of sales. But that is a pretty large margin...
      • 31161
      couldnt you get one next-day from digikey or newark etc?
      • mmartell
        • Oct 2013
        • 3189
        Overnight shipping ? Lol, I'm in Canada. I might as well call a service tech and give him the money.
        When I realized I needed the run capacitor it was 6pm and the shop was closed. Picked it up the following morning at 8am and had it installed and running by 9am. House was cold when the troops returned from school/work later in the day. So in this case I paid for convenience and when I do the math on average annual maintenence I was ok with it.
        That being said I did order a backup to cover my ass should that become necessary in the future
        • cheapie
          null
          • Jul 2010
          • 849
          I remember when the same thing happened to my well water pump (except that used a start cap, not a run cap).
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • valvashon
            Repair Success! Middle Atlantic UPS2200R-IP
            by valvashon
            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
            02-06-2024, 12:54 PM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • DrDos
            Unit runs but no speaker output kenwood KR-6030
            by DrDos
            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
            09-14-2025, 09:57 PM
          • nobbnobb1
            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
            by nobbnobb1
            Hi guys,
            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
            02-03-2022, 11:14 AM
