Just Repaired my Central Air Unit and Wouldn't You Know...
  • mmartell
    • Oct 2013
    • 3189
    ...Bad CAP! (could this be part of that whole Taiwan thing ? Lol)
    As an aside the shop here in town I got the part from charged me $44 + tax. Out of curiousity I had searched ebay and the part can be had for about $7. Wtf ? I realize with temps around 90F and a wife and kids to consider I can't wait for shipping but come on ! Do I have "sucker" written on my forehead or are these guys fucking thieves ?
    Re: Just Repaired my Central Air Unit and Wouldn't You Know...
    Shop has to pay for rent and staff, online retailer often doesn't or the costs are much lower with the number of sales. But that is a pretty large margin...
      • 30937
      couldnt you get one next-day from digikey or newark etc?
      • mmartell
        • Oct 2013
        • 3189
        Overnight shipping ? Lol, I'm in Canada. I might as well call a service tech and give him the money.
        When I realized I needed the run capacitor it was 6pm and the shop was closed. Picked it up the following morning at 8am and had it installed and running by 9am. House was cold when the troops returned from school/work later in the day. So in this case I paid for convenience and when I do the math on average annual maintenence I was ok with it.
        That being said I did order a backup to cover my ass should that become necessary in the future
        • cheapie
          null
          • Jul 2010
          • 849
          I remember when the same thing happened to my well water pump (except that used a start cap, not a run cap).
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • valvashon
            Repair Success! Middle Atlantic UPS2200R-IP
            by valvashon
            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
            02-06-2024, 12:54 PM
          • nobbnobb1
            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
            by nobbnobb1
            Hi guys,
            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
            02-03-2022, 11:14 AM
          • Gjackson
            Air-conditioning unit power supply failing to power up
            by Gjackson
            Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
            01-08-2022, 09:24 AM
          • navagator
            Hitachi Power Supply Unit Interchangeability
            by navagator
            I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
            Does anyone know if these 2 power supply boards are interchangeable?
            Thanks.
            01-08-2024, 07:53 PM
